Ana içeriğe geç
Wyze Cam V2 Speaker Replacement
Neye ihtiyacın var
  1. Wyze Cam V2 Speaker Replacement, Back Panel: adım 1, 1 resimden 1.
    • Open up the camera stand to expose the bottom plate of the camera.
    • Remove two 4 mm silver screws using the Phillips #0 screwdriver.
  2. Wyze Cam V2 Speaker Replacement: adım 2, 1 resimden 1.
    • Using the iFixit opening tool, carefully pry open the bottom plate to gain access to the camera's internals.
  3. Wyze Cam V2 Speaker Replacement: adım 3, 2 resimden 1. Wyze Cam V2 Speaker Replacement: adım 3, 2 resimden 2.
    • Open up the back panel using the iFixit opening tool and unclip the panel from the rest of the device.
    • Be careful of the charging port while taking it off.
  4. Wyze Cam V2 Speaker Replacement: adım 4, 2 resimden 1. Wyze Cam V2 Speaker Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    $3.99
  5. Wyze Cam V2 Speaker Replacement, Speaker: adım 5, 2 resimden 1. Wyze Cam V2 Speaker Replacement, Speaker: adım 5, 2 resimden 2.
    • Remove the two 6 mm screws from the back cover with a Phillips #0 screwdriver.
    • Carefully lift off the speaker plate.
  6. Wyze Cam V2 Speaker Replacement: adım 6, 2 resimden 1. Wyze Cam V2 Speaker Replacement: adım 6, 2 resimden 2.
    • Carefully remove the speaker using the spudger.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 128
