Ana içeriğe geç
X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement
Neye ihtiyacın var
  1. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Battery: adım 1, 1 resimden 1.
    • Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
    • Unclip the two clips to remove the battery cover.
  2. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: adım 2, 1 resimden 1.
    • Unplug the battery by pushing on the clip.
  3. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Underbody: adım 3, 1 resimden 1.
    • Unscrew the two 2.5mm Phillips #00 screws from each side
  4. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: adım 4, 1 resimden 1.
    • Remove the side skirt covers on each side of the car.
  5. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: adım 5, 2 resimden 1. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: adım 5, 2 resimden 2.
    • Lift up and remove the two side skirts.
  6. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: adım 6, 1 resimden 1.
    • Unscrew the two 2.5mm Phillips #00 screws from the front skirt of the car.
  7. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: adım 7, 1 resimden 1.
    • Lift the front part of the underbody and pull it out from the main underbody.
  8. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: adım 8, 2 resimden 1. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: adım 8, 2 resimden 2.
    • Unscrew the remaining seven 9mm Phillips #00 screws from the underbody of the car.
    • The second image shows a closer view of the rear three screws
  9. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: adım 9, 2 resimden 1. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: adım 9, 2 resimden 2.
    • Lift the main underbody from the shell of the car.
    • Lift up the body to expose the wiring and hardware underneath.
  10. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: adım 10, 1 resimden 1.
    • Remove the reflective sticker from the top of the body.
  11. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: adım 11, 1 resimden 1.
    • Unplug the wire connector.
  12. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Steering Column: adım 12, 3 resimden 1. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Steering Column: adım 12, 3 resimden 2. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Steering Column: adım 12, 3 resimden 3.
    • Unscrew the three 2.5mm Phillips #00 screws from the white steering column.
    • After removing the three screws, the steering column will pop out of position because of the springs underneath. To reassemble, put the springs back together as shown in picture #3.
  13. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Front Steering Motor: adım 13, 1 resimden 1.
    • Remove the three 1.6mm Phillips #000 screws from the black motor casing
  14. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: adım 14, 1 resimden 1.
    • Remove the front motor and its casing from the chassis of the car.
  15. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: adım 15, 2 resimden 1. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: adım 15, 2 resimden 2.
    • Remove the remaining three 1.6 mm Phillips #000 screws from the black motor casing
    • The second image shows the screws removed from the casing.
  16. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: adım 16, 1 resimden 1.
    • Pull out the front motor, making sure to keep the gears intact
Sonuç
Trent Peterson
454 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-3, Lancaster Spring 2015 Cal Poly, Team 24-3, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S24G3
3 Üyeler
9 adet Kılavuz yazıldı
Bir Yorum
How many volts is the battery?
DC2 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 531
