Ana içeriğe geç
XBOX Controller S Trigger Replacement
Neye ihtiyacın var
  1. XBOX Controller S Trigger Replacement, Shell: adım 1, 1 resimden 1.
    • Remove the seven 9.4 mm screws on the back of the controller using a Phillips #00 screwdriver.
    • One screw is hidden behind the sticker on the back of the controller. Peel that sticker back and remove that screw as well.
  2. XBOX Controller S Trigger Replacement: adım 2, 3 resimden 1. XBOX Controller S Trigger Replacement: adım 2, 3 resimden 2. XBOX Controller S Trigger Replacement: adım 2, 3 resimden 3.
    • Keep the controller facing down to prevent components from falling out.
    • Remove the back shell.
    • Flip the controller over and remove the front shell.
  3. XBOX Controller S Trigger Replacement, Trigger: adım 3, 2 resimden 1. XBOX Controller S Trigger Replacement, Trigger: adım 3, 2 resimden 2.
    • Carefully remove the motherboard from the shell.
  4. XBOX Controller S Trigger Replacement: adım 4, 3 resimden 1. XBOX Controller S Trigger Replacement: adım 4, 3 resimden 2. XBOX Controller S Trigger Replacement: adım 4, 3 resimden 3.
    • Desolder the three attachment points for the trigger, then unclip the trigger from the circuit board.
    • Clip in the new replacement trigger and solder the three attachment points.
Sonuç
WyattGripp
292 İtibar
3 adet Kılavuz yazıldı
Ekip
Texas Tech, Team 46-5, Johansen Fall 2025 Texas Tech, Team 46-5, Johansen Fall 2025 üyesi
TTU-JOHANSEN-F25S46G5
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 18
Son 30 gün: 20
Her zaman: 40
