Ana içeriğe geç
XPS M2010 MXP061 Memory Module Replacement
Neye ihtiyacın var
  1. XPS M2010 MXP061 Memory Module Replacement, Memory Cover Remove: adım 1, 1 resimden 1.
    • CAUTION: Before you begin the following procedure, follow the safety instructions in the Product Information Guide .
    • NOTICE: To prevent static damage to components inside your computer, discharge static electricity from your body before you touch any of your computer's electronic components. You can do so by touching an unpainted metal surface. If you leave the area, ground yourself again when you return to the computer.
    • NOTE: Memory modules purchased from Dell are covered under your computer warranty.
    • NOTE: To get maximum performance/dual-channel memory bandwidth capability, both memory module connectors must contain memory modules and the modules must be of the same size and configuration.
    • NOTICE: To help prevent damage to the system board, you must remove the main battery before you begin working inside the computer
    • With the computer still turned over, loosen the captive screw on the memory module cover and slide the cover toward the back of the computer to remove it.
    FixBot'a Sor
    Yorum Ekle
  2. XPS M2010 MXP061 Memory Module Replacement, Removing Securing Clamps: adım 2, 1 resimden 1.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    FixBot'a Sor
    Yorum Ekle
  3. XPS M2010 MXP061 Memory Module Replacement, Removeing memory Module: adım 3, 1 resimden 1.
    • Remove the module from the connector on the system board.
    FixBot'a Sor
    Yorum Ekle
  4. XPS M2010 MXP061 Memory Module Replacement, Replacing the Memory Module: adım 4, 1 resimden 1.
    • Align the notch on the edge of the memory module connector with the tab in the connector on the system board, and slide the module firmly into the connector at a 45-degree angle.
    FixBot'a Sor
    Yorum Ekle
  5. XPS M2010 MXP061 Memory Module Replacement, Seating the Memory Module in place.: adım 5, 1 resimden 1.
    • Rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
    FixBot'a Sor
    Yorum Ekle
  6. XPS M2010 MXP061 Memory Module Replacement, Replace the memory cover: adım 6, 1 resimden 1.
    • Replace the memory cover. Align the notches in the cover with the tabs on the base, slide the cover toward the front of the computer, and tighten the captive screw.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Johnathan Hammond
46.149 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
2.003 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 42
Her zaman: 592
