Ana içeriğe geç
XQ-673H Power Cord Replacement
Neye ihtiyacın var
    1. XQ-673H Power Cord Replacement, Power Cord: adım 1, 1 resimden 1.
      • Turn the Kitchen Gourmet upside down.
      • Make sure the device is unplugged before continuing.
      FixBot'a Sor
      Yorum Ekle
    2. XQ-673H Power Cord Replacement: adım 2, 3 resimden 1. XQ-673H Power Cord Replacement: adım 2, 3 resimden 2. XQ-673H Power Cord Replacement: adım 2, 3 resimden 3.
      • Using a phillips #1 screwdriver, remove the six 10mm screws found on the bottom of the device.
      • Remove the bottom cover.
      FixBot'a Sor
      Yorum Ekle
    3. XQ-673H Power Cord Replacement: adım 3, 3 resimden 1. XQ-673H Power Cord Replacement: adım 3, 3 resimden 2. XQ-673H Power Cord Replacement: adım 3, 3 resimden 3.
      • Using a Phillips #1 screwdriver, unscrew the 11mm screws.
      • Remove the plastic bar that is holding the Power Cord down.
      FixBot'a Sor
      Yorum Ekle
    4. XQ-673H Power Cord Replacement: adım 4, 2 resimden 1. XQ-673H Power Cord Replacement: adım 4, 2 resimden 2.
      • Using scissors, carefully cut the zip tie.
      • Careful not to cut the Power Cord.
      FixBot'a Sor
      Yorum Ekle
    5. XQ-673H Power Cord Replacement: adım 5, 3 resimden 1. XQ-673H Power Cord Replacement: adım 5, 3 resimden 2. XQ-673H Power Cord Replacement: adım 5, 3 resimden 3.
      • Using small needle nose pliers, gently squeeze the side so it allows the metal clamp to open up.
      • Gently pull off the plastic cover.
      • Repeat this step with the other plastic cover.
      FixBot'a Sor
      Yorum Ekle
    6. XQ-673H Power Cord Replacement: adım 6, 2 resimden 1. XQ-673H Power Cord Replacement: adım 6, 2 resimden 2.
      • Remove the Power Cord from the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Sean Perry
452 İtibar
4 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 30
Her zaman: 557
