Ana içeriğe geç
XQ-673H Power Cord Replacement
Neye ihtiyacın var
  1. XQ-673H Power Cord Replacement, Power Cord: adım 1, 1 resimden 1.
    • Turn the Kitchen Gourmet upside down.
    • Make sure the device is unplugged before continuing.
  2. XQ-673H Power Cord Replacement: adım 2, 3 resimden 1. XQ-673H Power Cord Replacement: adım 2, 3 resimden 2. XQ-673H Power Cord Replacement: adım 2, 3 resimden 3.
    • Using a phillips #1 screwdriver, remove the six 10mm screws found on the bottom of the device.
    • Remove the bottom cover.
  3. XQ-673H Power Cord Replacement: adım 3, 3 resimden 1. XQ-673H Power Cord Replacement: adım 3, 3 resimden 2. XQ-673H Power Cord Replacement: adım 3, 3 resimden 3.
    • Using a Phillips #1 screwdriver, unscrew the 11mm screws.
    • Remove the plastic bar that is holding the Power Cord down.
  4. XQ-673H Power Cord Replacement: adım 4, 2 resimden 1. XQ-673H Power Cord Replacement: adım 4, 2 resimden 2.
    • Using scissors, carefully cut the zip tie.
    • Careful not to cut the Power Cord.
  5. XQ-673H Power Cord Replacement: adım 5, 3 resimden 1. XQ-673H Power Cord Replacement: adım 5, 3 resimden 2. XQ-673H Power Cord Replacement: adım 5, 3 resimden 3.
    • Using small needle nose pliers, gently squeeze the side so it allows the metal clamp to open up.
    • Gently pull off the plastic cover.
    • Repeat this step with the other plastic cover.
  6. XQ-673H Power Cord Replacement: adım 6, 2 resimden 1. XQ-673H Power Cord Replacement: adım 6, 2 resimden 2.
    • Remove the Power Cord from the device.
Sonuç
Sean Perry
425 İtibar
4 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 7
Her zaman: 211
