Ana içeriğe geç
XQ-673H Power Switch Replacement
Neye ihtiyacın var
  1. XQ-673H Power Switch Replacement, Power Switch: adım 1, 1 resimden 1.
    • Turn the Kitchen Gourmet upside down.
    • Make sure the device is unplugged before continuing.
  2. XQ-673H Power Switch Replacement: adım 2, 3 resimden 1. XQ-673H Power Switch Replacement: adım 2, 3 resimden 2. XQ-673H Power Switch Replacement: adım 2, 3 resimden 3.
    • Using a phillips #1 screwdriver, remove the six 10mm screws found on the bottom of the device.
    • Remove the bottom cover.
  3. XQ-673H Power Switch Replacement: adım 3, 2 resimden 1. XQ-673H Power Switch Replacement: adım 3, 2 resimden 2.
    • Using a Plastic Opening Tool, carefully slide back the three power connectors for the Power Switch until fully removed.
  4. XQ-673H Power Switch Replacement: adım 4, 3 resimden 1. XQ-673H Power Switch Replacement: adım 4, 3 resimden 2. XQ-673H Power Switch Replacement: adım 4, 3 resimden 3.
    • Gently squeeze the sides of the Power Switch, while using a Spudger to help pop out the Power Switch.
Sonuç
Sean Perry
425 İtibar
4 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 310
