Ana içeriğe geç
XQ-673H Water Tubes Replacement
Neye ihtiyacın var
    1. XQ-673H Water Tubes Replacement, Water Tubes: adım 1, 1 resimden 1.
      • Make sure the device is unplugged before continuing.
      • Turn the Kitchen Gourmet upside down.
      FixBot'a Sor
      Yorum Ekle
    2. XQ-673H Water Tubes Replacement: adım 2, 3 resimden 1. XQ-673H Water Tubes Replacement: adım 2, 3 resimden 2. XQ-673H Water Tubes Replacement: adım 2, 3 resimden 3.
      • Using a Phillips #1 screwdriver, remove the six 10mm screws found on the bottom of the device.
      • Remove the bottom cover.
      FixBot'a Sor
      Yorum Ekle
    3. XQ-673H Water Tubes Replacement: adım 3, 2 resimden 1. XQ-673H Water Tubes Replacement: adım 3, 2 resimden 2.
      • Using a Phillips #1 screwdriver, remove the six 12mm screws.
      • Some screws are not visible from this photo, but their location is highlighted by the circles.
      FixBot'a Sor
      Yorum Ekle
    4. XQ-673H Water Tubes Replacement: adım 4, 3 resimden 1. XQ-673H Water Tubes Replacement: adım 4, 3 resimden 2. XQ-673H Water Tubes Replacement: adım 4, 3 resimden 3.
      • Using small needle nose pliers, squeeze the metal that is covering the tube.
      • Carefully slide down the metal covering.
      • Repeat this step for the other tube.
      FixBot'a Sor
      Yorum Ekle
    5. XQ-673H Water Tubes Replacement: adım 5, 2 resimden 1. XQ-673H Water Tubes Replacement: adım 5, 2 resimden 2.
      • Using your fingers, gently slide off the Water Tubes.
      FixBot'a Sor
      Yorum Ekle
    6. XQ-673H Water Tubes Replacement: adım 6, 2 resimden 1. XQ-673H Water Tubes Replacement: adım 6, 2 resimden 2.
      • Carefully lift the bottom section off the device.
      FixBot'a Sor
      Yorum Ekle
    7. XQ-673H Water Tubes Replacement: adım 7, 2 resimden 1. XQ-673H Water Tubes Replacement: adım 7, 2 resimden 2.
      • Remove both of the Water Tubes completely.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sean Perry
452 İtibar
4 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 39
Her zaman: 1,104
