Ana içeriğe geç
XQ-673H Water Tubes Replacement
Neye ihtiyacın var
  1. XQ-673H Water Tubes Replacement, Water Tubes: adım 1, 1 resimden 1.
    • Make sure the device is unplugged before continuing.
    • Turn the Kitchen Gourmet upside down.
  2. XQ-673H Water Tubes Replacement: adım 2, 3 resimden 1. XQ-673H Water Tubes Replacement: adım 2, 3 resimden 2. XQ-673H Water Tubes Replacement: adım 2, 3 resimden 3.
    • Using a Phillips #1 screwdriver, remove the six 10mm screws found on the bottom of the device.
    • Remove the bottom cover.
  3. XQ-673H Water Tubes Replacement: adım 3, 2 resimden 1. XQ-673H Water Tubes Replacement: adım 3, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the six 12mm screws.
    • Some screws are not visible from this photo, but their location is highlighted by the circles.
  4. XQ-673H Water Tubes Replacement: adım 4, 3 resimden 1. XQ-673H Water Tubes Replacement: adım 4, 3 resimden 2. XQ-673H Water Tubes Replacement: adım 4, 3 resimden 3.
    • Using small needle nose pliers, squeeze the metal that is covering the tube.
    • Carefully slide down the metal covering.
    • Repeat this step for the other tube.
  5. XQ-673H Water Tubes Replacement: adım 5, 2 resimden 1. XQ-673H Water Tubes Replacement: adım 5, 2 resimden 2.
    • Using your fingers, gently slide off the Water Tubes.
  6. XQ-673H Water Tubes Replacement: adım 6, 2 resimden 1. XQ-673H Water Tubes Replacement: adım 6, 2 resimden 2.
    • Carefully lift the bottom section off the device.
  7. XQ-673H Water Tubes Replacement: adım 7, 2 resimden 1. XQ-673H Water Tubes Replacement: adım 7, 2 resimden 2.
    • Remove both of the Water Tubes completely.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sean Perry
425 İtibar
4 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 723
