Ana içeriğe geç
Giriş
Use this guide if the connections in the back of your Xbox 360 E aren't working. Replacing the motherboard requires a little more time than replacing other parts of your Xbox.
  1. Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  2. Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  3. Continue sliding the spudger along the perimeter of the left grated face of the Xbox. Pull the top panel off. Pull the top panel off.
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
  4. Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
    • Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
    • Pull up on the spudger like a lever, keeping it pressed firmly into the crevice.
  5. Slide the spudger along the crevice to separate the grated face and the top body. Slide the spudger along the crevice to separate the grated face and the top body.
    • Slide the spudger along the crevice to separate the grated face and the top body.
  6. Wiggle the spudger in the crevice as you slide the spudger to loosen the bottom plate. Slide the spudger along the crevice, going completely about the perimeter of the bottom panel. Pull the bottom panel off.
    • Wiggle the spudger in the crevice as you slide the spudger to loosen the bottom plate.
    • Slide the spudger along the crevice, going completely about the perimeter of the bottom panel.
    • Pull the bottom panel off.
  7. In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off. In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off. In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off.
    • In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off.
  8. Beginning on the left side without the grate, run the spudger along the crevice until you've reached the grated part, while holding the part that's being separated as you go. Beginning on the left side without the grate, run the spudger along the crevice until you've reached the grated part, while holding the part that's being separated as you go. Beginning on the left side without the grate, run the spudger along the crevice until you've reached the grated part, while holding the part that's being separated as you go.
    • Beginning on the left side without the grate, run the spudger along the crevice until you've reached the grated part, while holding the part that's being separated as you go.
  9. Keep holding the partially separated panel open. It's easiest to do this by wedging a spudger into the opening but can also be held open by your hands. Rotate the Xbox to the left to locate the clip connecting the front panel to the body. Insert the spudger inside the gap to release the clip. This may require wiggling the spudger. The clip will pop off, making the front panel looser. Rotate the Xbox to the left to locate the clip connecting the front panel to the body. Insert the spudger inside the gap to release the clip. This may require wiggling the spudger. The clip will pop off, making the front panel looser.
    • Keep holding the partially separated panel open. It's easiest to do this by wedging a spudger into the opening but can also be held open by your hands.
    • Rotate the Xbox to the left to locate the clip connecting the front panel to the body. Insert the spudger inside the gap to release the clip. This may require wiggling the spudger. The clip will pop off, making the front panel looser.
    My actual disk tray came off the track looking into the best way to repair it
    David Mitchell - Yanıt
  10. Flip the Xbox so the opposite side is towards you. Make sure to keep the separation open. Locate the other clip and insert the spudger to remove it. Locate the other clip and insert the spudger to remove it.
    • Flip the Xbox so the opposite side is towards you. Make sure to keep the separation open.
    • Locate the other clip and insert the spudger to remove it.
  11. Android Tamir Setleri
    A new screen or battery is one kit away.
    Hemen Alışveriş Yapın
  12. Continue to run the spudger along the crease to release any further clips that may still be attatched. Do no pull off the panel too fast because you don't want to damage the ribbon cable. Slowly pull away the panel.
    • Continue to run the spudger along the crease to release any further clips that may still be attatched.
    • Do no pull off the panel too fast because you don't want to damage the ribbon cable. Slowly pull away the panel.
    • Now that the front panel has been released from its clips you can pull off the front panel.
  13. Find the brown section where the ribbon  cable enters the green board. Flip the brown part up and pull out the plastic tab at the end of the ribbon. Find the brown section where the ribbon  cable enters the green board. Flip the brown part up and pull out the plastic tab at the end of the ribbon. Find the brown section where the ribbon  cable enters the green board. Flip the brown part up and pull out the plastic tab at the end of the ribbon.
    • Find the brown section where the ribbon cable enters the green board. Flip the brown part up and pull out the plastic tab at the end of the ribbon.
  14. Looking at the body of the device, locate the green panel to the right of the CD drive. Remove the two 6 mm screws located on the top left and middle right with a T8 Torx screwdriver. Grip the middle of the green board and gently pull it out.
    • Looking at the body of the device, locate the green panel to the right of the CD drive.
    • Remove the two 6 mm screws located on the top left and middle right with a T8 Torx screwdriver.
    • Grip the middle of the green board and gently pull it out.
  15. Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
    • Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
    In my case it was a T10 Screw, not T9
    Limer o - Yanıt
  16. Firmly grip the green Wi-Fi card and pull it out of the Xbox. Firmly grip the green Wi-Fi card and pull it out of the Xbox.
    • Firmly grip the green Wi-Fi card and pull it out of the Xbox.
    On that wifi card there is a little port that you can plug and old router antena into. Any idea what its called?
    Tyler Goyette - Yanıt
  17. Orient the Xbox so the bottom body is facing upwards. Make sure you see the rubber feet to know you have the correct side of the device. Lift the bottom body slightly away from the core at a 45 degree angle. Lift the bottom body slightly away from the core at a 45 degree angle.
    • Orient the Xbox so the bottom body is facing upwards. Make sure you see the rubber feet to know you have the correct side of the device.
    • Lift the bottom body slightly away from the core at a 45 degree angle.
  18. Rotate the Xbox so you are now looking at the back of the device. This step of disassembly requires the removal of the warranty sticker.  This will void your warranty.  Check the main page for a link to warranty information from Microsoft.
    • Rotate the Xbox so you are now looking at the back of the device.
    • This step of disassembly requires the removal of the warranty sticker. This will void your warranty. Check the main page for a link to warranty information from Microsoft.
    • Remove the sticker from the back of the Xbox.
    • The sticker is not needed for reassembly.
  19. Turn the Xbox to the left to locate the clip holding the body together. With a spudger, press up on the clip like a latch. Move to the far end to undo the other clip the same way. With a spudger, press up on the clip like a latch. Move to the far end to undo the other clip the same way.
    • Turn the Xbox to the left to locate the clip holding the body together.
    • With a spudger, press up on the clip like a latch. Move to the far end to undo the other clip the same way.
  20. Push the spudger into the crevice. Slide the spudger along the vertical crevice to detach the last clip. The bottom body should slide off after this. Push the spudger into the crevice. Slide the spudger along the vertical crevice to detach the last clip. The bottom body should slide off after this.
    • Push the spudger into the crevice. Slide the spudger along the vertical crevice to detach the last clip. The bottom body should slide off after this.
  21. Remove the five long black 55 mm screws labeled C2-5 and C7 with a T9 Torx screwdriver. Carefully flip the device and pull off the body by lifting from the metal section that is attached to the plastic exterior.
    • Remove the five long black 55 mm screws labeled C2-5 and C7 with a T9 Torx screwdriver.
    • Carefully flip the device and pull off the body by lifting from the metal section that is attached to the plastic exterior.
    C1 - C5 screws
    Jeff Gray - Yanıt
    And not T9 - the're T10 screws
    Limer o - Yanıt
    Missing some steps here…. Where are the clips holding the sides together? To go straight from “Remove bottom cover” to “Device is apart” is a bit… lacking.
    Aksel Barnes - Yanıt
  22. Use your fingers to unplug the blue ribbon cable from the CD drive. Use your fingers to unplug the blue ribbon cable from the CD drive.
    • Use your fingers to unplug the blue ribbon cable from the CD drive.
  23. Use tweezers to unplug the blue and pink wires.
    • Use tweezers to unplug the blue and pink wires.
  24. Lift the front end of the CD drive and take it out.
    • Lift the front end of the CD drive and take it out.
  25. From the bottom of your Xbox, take your T9 torx screwdriver and take out all of the 11 mm screws labelled B1-7 Don't forget a screw on the side of the Xbox next to the power plug.
    • From the bottom of your Xbox, take your T9 torx screwdriver and take out all of the 11 mm screws labelled B1-7
    • Don't forget a screw on the side of the Xbox next to the power plug.
  26. Flip the Xbox over and take out the heat sink plastic shield. Flip the Xbox over and take out the heat sink plastic shield.
    • Flip the Xbox over and take out the heat sink plastic shield.
  27. Unplug the red cable. Unplug the blue cable. Take the hard drive assembly by the long plastic arm and lift the entire thing out.
    • Unplug the red cable.
    • Unplug the blue cable.
    • Take the hard drive assembly by the long plastic arm and lift the entire thing out.
  28. Flip the Xbox to the back and take your T10 torx screwdriver and take out the last four 6 mm screws labelled A1-4.
    • Flip the Xbox to the back and take your T10 torx screwdriver and take out the last four 6 mm screws labelled A1-4.
    It is T8 for me
    Thomas Dorsey - Yanıt
  29. Back to the top of the Xbox, take out the metal and plastic insert. Place two fingers in between the grooves in the metal body and the motherboard and pull up slightly. Do not pull up from the side with the plugs like the HDMI and internet. As the motherboard comes up, switch to the left side and continue pulling the motherboard up.
    • Back to the top of the Xbox, take out the metal and plastic insert.
    • Place two fingers in between the grooves in the metal body and the motherboard and pull up slightly. Do not pull up from the side with the plugs like the HDMI and internet.
    • As the motherboard comes up, switch to the left side and continue pulling the motherboard up.
    • Once that side of the motherboard is out, lift the rest of the motherboard away from the metal body.
Sonuç
26 farklı kişi bu kılavuzu tamamladı.
Bryce
1.061 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 2-11, Amido Winter 2014 Cal Poly, Team 2-11, Amido Winter 2014 üyesi
CPSU-AMIDO-W14S2G11
4 Üyeler
22 adet Kılavuz yazıldı
3 Yorum
Where can I get the motherboard?
Derek Bullard - Yanıt
Need a motherboard.....
supergametime - Yanıt
How did you go finding one ? , I gotta get one I think , any chance u could get hold of me by email or I'm on fb ? , just wanna ask you about something with xbox memory n error cap
Daniel Leach -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 20
Son 30 Gün: 101
Her zaman: 15,091
