Ana içeriğe geç
Xbox 360 E Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Xbox 360 E Wi-Fi Card Replacement, Top Panel: adım 1, 1 resimden 1.
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
    FixBot'a Sor
    Yorum Ekle
  2. Xbox 360 E Wi-Fi Card Replacement: adım 2, 1 resimden 1.
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
    FixBot'a Sor
    Yorum Ekle
  3. Xbox 360 E Wi-Fi Card Replacement: adım 3, 3 resimden 1. Xbox 360 E Wi-Fi Card Replacement: adım 3, 3 resimden 2. Xbox 360 E Wi-Fi Card Replacement: adım 3, 3 resimden 3.
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
    FixBot'a Sor
    Yorum Ekle
  4. Xbox 360 E Wi-Fi Card Replacement, Wi-Fi Card: adım 4, 1 resimden 1.
    • Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
    FixBot'a Sor
    Yorum Ekle
  5. Xbox 360 E Wi-Fi Card Replacement: adım 5, 2 resimden 1. Xbox 360 E Wi-Fi Card Replacement: adım 5, 2 resimden 2.
    • Firmly grip the green Wi-Fi card and pull it out of the Xbox.
    FixBot'a Sor
    Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Jennifer
2.287 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-11, Amido Winter 2014 Cal Poly, Team 2-11, Amido Winter 2014 üyesi
CPSU-AMIDO-W14S2G11
4 Üyeler
55 adet Kılavuz yazıldı
1Rehber Yorum
Nicely done!
dakota.1970 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 35
Son 30 gün: 136
Her zaman: 13,076
