Giriş
Make your Xbox 360 S look shiny and new by replacing the outer panels.
Neye ihtiyacın var
Push the latch holding down the hard drive cover to the left.
Pull the hard drive cover away from the console.
Insert a metal spudger through the left middle slit of the bottom bezel, and between the bottom edge of the clip and the left case.
Simultaneously pull the bottom bezel up and rotate the spudger away from the console to free the clip.
In a similar fashion, free the clip at the front of the bottom bezel's left edge.
48 farklı kişi bu kılavuzu tamamladı.
