Ana içeriğe geç
Xbox 360 S Fan Replacement
Neye ihtiyacın var
  1. Xbox 360 S Fan Replacement, Top Panel: adım 1, 1 resimden 1.
    • In the following steps, you will remove the top vent, secured to the top panel by the thirteen clips shown.
    • Take care when removing the fan vent not to break any of the plastic clips.
  2. Xbox 360 S Fan Replacement: adım 2, 2 resimden 1. Xbox 360 S Fan Replacement: adım 2, 2 resimden 2.
    • Orient the console so that the words "XBOX 360" on the sides are right-side up, and the faceplate is facing to the left.
    • Insert a metal spudger between the top vent and the top bezel near the rear of the Xbox.
    • Rotate the spudger away from the console, prying the edge of the fan vent up until the two plastic clips come free.
    • Be sure to rotate the spudger far enough so that the plastic clips clear the silver rim of the top bezel.
    Whoever gave that tool the name “spudger” needs to be shot in the face.
    Richard - Yanıt
    This step is and the others following are to rough and not needed, simply put smth in between the lamellar and push it up with littlebit pressure thats better for the plastic parts.
    TheSupport - Yanıt
  3. Xbox 360 S Fan Replacement: adım 3, 3 resimden 1. Xbox 360 S Fan Replacement: adım 3, 3 resimden 2. Xbox 360 S Fan Replacement: adım 3, 3 resimden 3.
    • Insert a metal spudger between the fan vent and top bezel along the left side of the console.
    • In the same manner described above, begin prying the left side of the top vent away from the top bezel.
    • Continue prying along the left side of the device, freeing all the clips on that side.
  4. Xbox 360 S Fan Replacement: adım 4, 2 resimden 1. Xbox 360 S Fan Replacement: adım 4, 2 resimden 2.
    • Lift the fan vent up from the freed left side to disengage the clips along the right side.
    • Remove the entire fan vent.
  5. Xbox 360 S Fan Replacement: adım 5, 2 resimden 1. Xbox 360 S Fan Replacement: adım 5, 2 resimden 2.
    • In the following steps, you will be releasing the six clips highlighted in red.
    • Each clip can be undone by inserting a metal spudger underneath the bottom edge of the clip. Once underneath the bottom edge, simply prying away from the console will free the clip.
    see the red boxes specially in image
    Restrict - Yanıt
  6. Xbox 360 S Fan Replacement: adım 6, 2 resimden 1. Xbox 360 S Fan Replacement: adım 6, 2 resimden 2.
    • Orient the console so that the left case is facing toward you and the faceplate is facing toward the right.
    • Insert a metal spudger through the front-most slit on the left edge of the top bezel and between the bottom edge of the clip and the left case, as described above.
    • Simultaneously rotate the spudger away from the console and pull up on the top bezel to free the clip.
    • You will hear a "pop" signifying that the clip cleared its catch.
    So I got the fan filter thing off, but the black edge plate thing isn't coming off. All I did was warp my flathead screwdriver and scratch the console.
    HumidTater - Yanıt
  7. Xbox 360 S Fan Replacement: adım 7, 2 resimden 1. Xbox 360 S Fan Replacement: adım 7, 2 resimden 2.
    • Using the same method described above, free the two remaining clips along the left edge of the top bezel.
  8. Xbox 360 S Fan Replacement: adım 8, 1 resimden 1.
    • Grab the entire top panel with your hands, lift up the entire left edge high enough to rest the separated clips on top of the left case.
    • You may have to go back with a spudger and undo any clips that have re-attached.
    • The top panel will not come free of the console yet.
  9. Xbox 360 S Fan Replacement: adım 9, 2 resimden 1. Xbox 360 S Fan Replacement: adım 9, 2 resimden 2.
    • Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
    • Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
    • While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
  10. Xbox 360 S Fan Replacement: adım 10, 2 resimden 1. Xbox 360 S Fan Replacement: adım 10, 2 resimden 2.
    • In the same manner as described in the previous steps, release the middle and front clips along the right edge of the top panel.
  11. Xbox 360 S Fan Replacement: adım 11, 1 resimden 1.
    • Lift the top panel off the device.
    • You may have to go back with a spudger and undo any clips that have re-attached to the console.
  12. Xbox 360 S Fan Replacement, Hard Drive: adım 12, 3 resimden 1. Xbox 360 S Fan Replacement, Hard Drive: adım 12, 3 resimden 2. Xbox 360 S Fan Replacement, Hard Drive: adım 12, 3 resimden 3.
    • Orient the Xbox 360 S so that the bottom of the console is facing toward you.
    • Push the latch holding down the hard drive cover to the left.
    • Pull the hard drive cover away from the console.
  13. Xbox 360 S Fan Replacement: adım 13, 3 resimden 1. Xbox 360 S Fan Replacement: adım 13, 3 resimden 2. Xbox 360 S Fan Replacement: adım 13, 3 resimden 3.
    • Firmly grasp the fabric tab labeled with the size of the hard drive (e.g. "250 GB") attached to the hard drive.
    • Pull the hard drive straight out of the console.
    • The fabric tab is attached to a catch further inside the hard drive housing. It will take some force to pull the hard drive out.
    If i buy a new xbox 360 and replace the hardrive inside with my own, will i have my account and saves? or will i have to recover my account and start over?
    yamboboy - Yanıt
    You will still have your saves and account if you replace your hard drive in the new xbox
    Robert Miller -
    hola tengo un disco de laptop y quiero ponerle 100 juegos como puedo hacer la xbox me reconose el disco y todo lo configuro pero cuando conecto a mi pc para pasar los juejosel emulador no me deja
    Cesar Tourreilles - Yanıt
    My fabric was accidentally ripped off years ago. What do I do?
    org 2026 - Yanıt
    Stick another bit on there
    Josh Cool -
  14. Xbox 360 S Fan Replacement, Bottom Panel: adım 14, 1 resimden 1.
    • In the following steps, you will remove the bottom vent.
    • It is attached to the bottom panel by the seven clips shown.
  15. Xbox 360 S Fan Replacement: adım 15, 2 resimden 1. Xbox 360 S Fan Replacement: adım 15, 2 resimden 2.
    • Orient the Xbox 360 S so that the hard drive port is facing up and the faceplate is facing to the left.
    • Insert a metal spudger between the black bottom vent and the silver rim of the bottom bezel, in the rear right corner of the vent.
    • Rotate the spudger away from the console, prying the vent up from the bottom bezel.
    • Be sure to rotate the spudger far enough so that the clips on the vent are lifted past the silver rim of the bottom bezel.
  16. Xbox 360 S Fan Replacement: adım 16, 3 resimden 1. Xbox 360 S Fan Replacement: adım 16, 3 resimden 2. Xbox 360 S Fan Replacement: adım 16, 3 resimden 3.
    • In the same manner as described above, pry the two remaining clips on the bottom right edge.
    • All of the clips along both the right and front edge should now be free. If other clips have come undone as well, that is fine.
  17. Xbox 360 S Fan Replacement: adım 17, 2 resimden 1. Xbox 360 S Fan Replacement: adım 17, 2 resimden 2.
    • Remove the bottom vent by lifting it away from the bottom bezel.
  18. Xbox 360 S Fan Replacement: adım 18, 2 resimden 1. Xbox 360 S Fan Replacement: adım 18, 2 resimden 2.
    • In the following steps, you will remove the bottom bezel, which is attached to the rest of the console by the six clips shown.
    • The clips shown in red can be detached by inserting a metal spudger underneath the bottom edge of the clip. Once underneath the bottom edge, simply prying away from the console will free the clip.
  19. Xbox 360 S Fan Replacement: adım 19, 2 resimden 1. Xbox 360 S Fan Replacement: adım 19, 2 resimden 2.
    • Insert a metal spudger through the slit near the rear left corner of the bottom bezel.
    • Rotate the spudger away from the device while lifting the rear bezel up with the other hand.
    • You may hear a "pop" signifying the clip has cleared its catch.
    These are pretty awkward to remove, but once you understand how they work its easy enough. The goal here is to slot the spudger THROUGH the gap of the silver tabs (visible in previous steps image, circled) and then pry. Put pressure against the wall of the Xbox case and push downwards, once you feel the spudger slot in, then apply force away from the Xbox and pull up a little with your free hand.
    Spaced Invader - Yanıt
  20. Xbox 360 S Fan Replacement: adım 20, 2 resimden 1. Xbox 360 S Fan Replacement: adım 20, 2 resimden 2.
    • Insert a metal spudger through the left middle slit of the bottom bezel, and between the bottom edge of the clip and the left case.
    • Simultaneously pull the bottom bezel up and rotate the spudger away from the console to free the clip.
    • In a similar fashion, free the clip at the front of the bottom bezel's left edge.
    • The entire left side of the bottom bezel should now be free.
  21. Xbox 360 S Fan Replacement: adım 21, 2 resimden 1. Xbox 360 S Fan Replacement: adım 21, 2 resimden 2.
    • Turn the console around so that the faceplate is facing to the right and the right case is facing toward you.
    • Insert the spudger into the rear-most slit on the right edge of the bottom bezel, and wedge it behind the clip by pushing the spudger down while pushing the tip of the spudger against the right case.
    • Simultaneously release the clip and pull the bottom bezel up.
    • This clip is especially hard to remove. Some force will be required to insert the spudger correctly.
  22. Xbox 360 S Fan Replacement: adım 22, 1 resimden 1.
    • This clip does not have a slit in the bezel to guide you. You can locate the clip by looking under the bezel near the hard drive slot.
    • Insert a spudger between the silver rim and bottom bezel directly above the clip shown.
    • Release the clip while pulling up on the bottom bezel.
  23. Xbox 360 S Fan Replacement: adım 23, 2 resimden 1. Xbox 360 S Fan Replacement: adım 23, 2 resimden 2.
    • This clip is smaller than the others and should not be removed from above like the others.
    • Lift the left edge of the bottom bezel up enough to gain clearance.
    • Insert a metal spudger behind the left edge of the last clip, and push the clip away from the right case.
  24. Xbox 360 S Fan Replacement, Left Case: adım 24, 1 resimden 1.
    • Opening your Xbox 360 any further will require breaking or removing the warranty sticker on the outer case. Your Microsoft warranty for any components not directly attached to the logic board will likely be voided by removing this seal.
    Does not void the warranty in the United States according to the FTC that sent a cease and desist letter directly to Microsoft about this exact issue.
    Jeff - Yanıt
  25. Xbox 360 S Fan Replacement: adım 25, 2 resimden 1. Xbox 360 S Fan Replacement: adım 25, 2 resimden 2.
    • Orient the console right-side up, with the faceplate facing toward you.
    • Locate the two clips connecting the right and left case along the top edge of the console, behind the Wi-Fi card.
    • While pushing the left and right case away from each other with one hand, pry the clips away from the case with a metal spudger.
    Retiring the WiFi module, this task gets a lot easier
    Luismi Carmona - Yanıt
  26. Xbox 360 S Fan Replacement: adım 26, 2 resimden 1. Xbox 360 S Fan Replacement: adım 26, 2 resimden 2.
    • Continue to hold the two cases apart to prevent the clips reattaching.
    • Insert a spudger between the right and left cases to hold them separate while you work elsewhere.
  27. Xbox 360 S Fan Replacement: adım 27, 2 resimden 1. Xbox 360 S Fan Replacement: adım 27, 2 resimden 2.
    • Flip the Xbox over so the faceplate is facing left, and the left case is facing toward you.
    • While pushing the left and right cases apart with one hand, free one clip located beside the hard drive slot.
  28. Xbox 360 S Fan Replacement: adım 28, 2 resimden 1. Xbox 360 S Fan Replacement: adım 28, 2 resimden 2.
    • Continue to hold the cases apart to prevent the clips from reattaching.
    • Place another spudger between the left and right cases directly below the clip.
  29. Xbox 360 S Fan Replacement: adım 29, 3 resimden 1. Xbox 360 S Fan Replacement: adım 29, 3 resimden 2. Xbox 360 S Fan Replacement: adım 29, 3 resimden 3.
    • Insert the flat edge of a metal spudger between the left and right cases where the warranty sticker used to be.
    • Pry the left case upwards to form a gap between the two cases, and slide the spudger in toward the left case.
    • Rotate the spudger upward to release the last clip.
    • The spudgers holding the top and bottom clips apart may be removed.
    if you make a hole right here like the link`s picture you can boot the lock
    https://scontent-mia.xx.fbcdn.net/hphoto...
    Midguet Garcia - Yanıt
    As the user above me said, please avoid doing it like shown in the guide. It just didn’t work on my Xbox (unless your goal is to destroy the plastic case). Instead, pick some small needle like object (the spudger was too short for this, I used the SIM bit of my iFixit driver kit) and find the right spot on the big sticker which is on the left in the pictures shown in the guide. That spot is just between the text and the column of logos (Dolby Digital, etc.) (https://team-xecuter.com/slim/slim_secre..., picture not mine). Poke it (don’t be too gentle, you have to apply some force) and you will hear the clip release.
    Davide Volta - Yanıt
    Both the above links are dead, i used this YouTube video which shows you the process of getting the hidden clip
    https://youtu.be/dFD94d6mDFE
    Kenny Montgomery - Yanıt
    I was able to open it by pushing on the sticker to unclamp the clip while another person helped me pull open the case.
    StellularWolf51 - Yanıt
    Here is a Video that shows the small hole behind the sticker, ist in german but ist good to see how to open that hidden clip easiely.
    https://www.youtube.com/watch?v=Bsy5IUVg...
    Michael Buß - Yanıt
  30. Xbox 360 S Fan Replacement: adım 30, 2 resimden 1. Xbox 360 S Fan Replacement: adım 30, 2 resimden 2.
    • Release one clip in the front left corner of the top edge securing the left case to the faceplate.
  31. Xbox 360 S Fan Replacement: adım 31, 2 resimden 1. Xbox 360 S Fan Replacement: adım 31, 2 resimden 2.
    • Flip the console over so the bottom is facing upward.
    • Release one clip in the front left corner of the bottom edge securing the left case to the faceplate.
    • Rotate the left case away from the device to release the last two inner clips.
    • Remove the left case.
  32. Xbox 360 S Fan Replacement, Faceplate: adım 32, 2 resimden 1. Xbox 360 S Fan Replacement, Faceplate: adım 32, 2 resimden 2.
    • Orient the console right-side-up, with the faceplate facing forward.
    • Release the clip near the front right corner of the top edge securing the right case to the faceplate.
    There are 4 black screw that has to be removed before you can detach the other cover. Please note
    emmoski4real - Yanıt
    Sorry, there 5screws, one in the middle and 4 at the edges
  33. Xbox 360 S Fan Replacement: adım 33, 1 resimden 1.
    • Turn the console over, so that the bottom is facing upward, and the faceplate is facing forward.
    • Release the clip in the bottom right corner of the top edge securing the right case to the front case.
  34. Xbox 360 S Fan Replacement: adım 34, 2 resimden 1. Xbox 360 S Fan Replacement: adım 34, 2 resimden 2.
    • Lift the left edge of the faceplate upward to release the last two clips securing the faceplate to the right case.
    • Detach the faceplate from the rest of the device.
    • The faceplate is still attached to the console by a thin ribbon cable. Do not attempt to completely remove the faceplate yet.
    It is easier to perform step 40 before 34 (unscrew the long torx screws to make the right case flexible)
    Peter - Yanıt
    There isn’t 2 clips there is 4 clips
    Daniel Mattes - Yanıt
  35. Xbox 360 S Fan Replacement: adım 35, 3 resimden 1. Xbox 360 S Fan Replacement: adım 35, 3 resimden 2. Xbox 360 S Fan Replacement: adım 35, 3 resimden 3.
    • Using a spudger or fingernail, lift the clear blue tab away from the connector.
    • Slide the locking tab on the power switch board cable connector toward the top of the console.
    • The locking tab will only move about 2 mm.
    • Pull the power switch cable straight out of the connector.
    • The faceplate is now free of the rest of the console.
  36. Xbox 360 S Fan Replacement, RF Module: adım 36, 1 resimden 1.
    • Remove the two 5.6 mm T8 Torx screws securing the RF module to the metal case.
    On my disassembly during this part, I found the T9 Torx to be too big and had to use the T8 Torx instead.
    weitmeyerj - Yanıt
    The correct size is T8!
    thomasforster - Yanıt
    I guess you need to check for your own size : I used the TR9 as the TR8 was a little too loose.
    sirmyself - Yanıt
  37. Xbox 360 S Fan Replacement: adım 37, 2 resimden 1. Xbox 360 S Fan Replacement: adım 37, 2 resimden 2.
    • The RF module is still connected to the Xbox by a large USB-type connector.
    • Pull the board directly away from the Xbox to remove it.
    This step is not needed.
    Wade - Yanıt
    It may not be required but recommended. As you move the xbox around you could break this part. Removing it and placing it in a safe place keeps that from happening.
    junkyardjojo - Yanıt
    Is the rf module married to the mother board? Im trying to replace the piece but dont want to start if it is not compatible.
    jake - Yanıt
  38. Xbox 360 S Fan Replacement, Wi-Fi Board: adım 38, 3 resimden 1. Xbox 360 S Fan Replacement, Wi-Fi Board: adım 38, 3 resimden 2. Xbox 360 S Fan Replacement, Wi-Fi Board: adım 38, 3 resimden 3.
    • Remove the single T10 Torx screw holding in the wireless card.
    • Pull the Wi-Fi Board out of the console.
  39. Xbox 360 S Fan Replacement, Right Case: adım 39, 1 resimden 1.
    • This is the terminal point if you ever want to send your Xbox back to Microsoft for repair.
    • Remove the large white warranty sticker from the metal frame to expose a screw.
  40. Xbox 360 S Fan Replacement: adım 40, 1 resimden 1.
    • Remove the five 55.5 mm T10 Torx screws securing the right case to the metal frame.
  41. Xbox 360 S Fan Replacement: adım 41, 1 resimden 1.
    • Turn the Xbox over so the right case is facing up.
    • Lift the right case off by its metal framework.
  42. Xbox 360 S Fan Replacement, Optical Drive: adım 42, 2 resimden 1. Xbox 360 S Fan Replacement, Optical Drive: adım 42, 2 resimden 2.
    • Disconnect the optical drive data cable from the back of the optical drive.
    • Disconnect the power cable from the back of the optical drive.
  43. Xbox 360 S Fan Replacement: adım 43, 1 resimden 1.
    • Lift the optical drive out of the Xbox.
    Is there a specific Optical Drive that Microsoft uses in these or can I upgrade my drive?
    whitemare0 - Yanıt
    i took my drive out but when installed my replacement it would not work
    davidgardner301 - Yanıt
    WAS thinking of possibly trying to repair my son's Xbox 360S, by replacing the optical drive, but after looking at all the spudger steps to get to the drive and then your comment that the replacement might not actually work... forget about it! I ain't going to all that work for possibly nothing... t'ain't worth it!
    Anyone want a perfectly working Xbox 360S with a drive the spins game discs upon ejection? We've already bought a replacement, so this unit is for sale... name your price.
    Luposian -
    In regards to davidgardner301 comment there is a extra step they. Didn't show on this replacement guide in order for your new disk drive to work you will need to remove the origional board connected to thje origional drive that came with the system and soler that onto the new one its a tricky process however its a step most people over look
    Without the origional board the xbox will not accept the replacement drive only because each disk drive is coded to work with tat soecific xbox only so your out of luck if you already. Tossed out your old disk drive
    Eric Liu - Yanıt
    So I installed the drive but the thing keeps reading the games as dvds, hence; wont play them, why?
    BigD29853 - Yanıt
    The DVD drives are coded to the Motherboard. If you buy the same exact drive to replace the broken one. You will still need to either 1) transfer the DVD circuit board OR 2) get the Firmware from the old DVD drive using a PC and then transfer it to the New DVD. There are website regarding this procedure if you want to look it up.
    Lawrence - Yanıt
  44. Xbox 360 S Fan Replacement, Hard Drive Bracket: adım 44, 1 resimden 1.
    • Turn the console over so that the metal case is facing up.
    • Remove the single 11.3 mm gold T10 Torx screw from the hole marked "G."
    Could be preferable to do this step along with step #47 since the screws fasten the same plastic part.
    sirmyself - Yanıt
  45. Xbox 360 S Fan Replacement: adım 45, 2 resimden 1. Xbox 360 S Fan Replacement: adım 45, 2 resimden 2.
    • Lift the fan duct off the fan.
    • There is a locator peg underneath the fan duct (top right corner of the fan duct as viewed in the pictures). When reinstalling look down the screw hole to aid alignment.
  46. Xbox 360 S Fan Replacement: adım 46, 2 resimden 1. Xbox 360 S Fan Replacement: adım 46, 2 resimden 2.
    • Remove the single 9.2 mm T10 Torx screw securing the hard drive cable connector to the plastic bracket.
    • Lift the hard drive cable connector off the hard drive bracket.
  47. Xbox 360 S Fan Replacement: adım 47, 1 resimden 1.
    • Remove the 11.3 mm T10 Torx screw holding the hard drive bracket to the metal frame, near the DC-In port.
  48. Xbox 360 S Fan Replacement: adım 48, 1 resimden 1.
    • Lift the hard drive bracket out of the metal frame.
    I have a 4GB Xbox 360 slim and I bought a 500GB hard drive for it. I pushed the hard drive in its place and after I heard that click, I pushed it a little bit more to be shure that it's in place. I noticed that the hard drive bracket (the slide that holds the hard drive) it's elastic: after the hard drive is inserted, it wobbles (maybe to prevent hdd damage when the xbox is moved).
    My question is: how does the hard drive bracket work? is there a metal spring in its mechanism that allows it to wobble? Did I make any damage to it because I pushed the hard drive to be sure that it is in place? I don't want to teardwon my console to find that out.
    Thank you!
    atitus87 - Yanıt
  49. Xbox 360 S Fan Replacement, Fan: adım 49, 1 resimden 1.
    • Disconnect the fan cable by pulling its connector off the logic board.
    What is the size and name if the connector in the fan?
    Fernando Salazar - Yanıt
  50. Xbox 360 S Fan Replacement: adım 50, 3 resimden 1. Xbox 360 S Fan Replacement: adım 50, 3 resimden 2. Xbox 360 S Fan Replacement: adım 50, 3 resimden 3.
    • Unscrew the two 11.7 mm Phillips screws securing the fan to the heat sink in the bottom right and top left corners of the fan.
    • Remove the fan from the logic board assembly.
Sonuç
101 farklı kişi bu kılavuzu tamamladı.
Matthew Newsom
39.500 İtibar
67 adet Kılavuz yazıldı
7 Yorum
Do I need to buy a new fan, or does this tutorial basically use a method of cleaning things out to fix the fan?
Luke Beeler - Yanıt
A bit late I know, but if you’re getting this deep into the system, put in a new fan.
This tutorial was perfect.
Thank you Mr. Newsom!
David Adamski - Yanıt
Loved your instruction so easy to follow compared to all the other DIY sites I have visited. Thank you so much!!!!! Now do you have one on how to download and use torrent files?
jim7858 - Yanıt
what wrong with x360 s
Andrecious Gamble - Yanıt
So could I water cool this thing?
evan hardison - Yanıt
You probably could if you can get the waterblock to fit into the xbox. but the radiator and fans might be tricky unless you just have those outside the case.
Trenton Hayes -
i just used this guide to clean out my 2010 360s, RIP 360 marketplace
The terrarian man101 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 108
Son 30 gün: 411
Her zaman: 111,313
