Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Give your Xbox's wiggly hard drive a new bracket to sit in.
Neye ihtiyacın var
In the following steps, you will remove the top vent, secured to the top panel by the thirteen clips shown.
Orient the console so that the words "XBOX 360" on the sides are right-side up, and the faceplate is facing to the left.
Insert a metal spudger between the top vent and the top bezel near the rear of the Xbox.
Rotate the spudger away from the console, prying the edge of the fan vent up until the two plastic clips come free.
Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
Push the latch holding down the hard drive cover to the left.
Pull the hard drive cover away from the console.
Insert a metal spudger through the left middle slit of the bottom bezel, and between the bottom edge of the clip and the left case.
Simultaneously pull the bottom bezel up and rotate the spudger away from the console to free the clip.
In a similar fashion, free the clip at the front of the bottom bezel's left edge.
Release the clip near the front right corner of the top edge securing the right case to the faceplate.
Using a spudger or fingernail, lift the clear blue tab away from the connector.
Slide the locking tab on the power switch board cable connector toward the top of the console.
Pull the power switch cable straight out of the connector.
The faceplate is now free of the rest of the console.
Remove the two 5.6 mm T8 Torx screws securing the RF module to the metal case.
Remove the single T10 Torx screw holding in the wireless card.
Pull the Wi-Fi Board out of the console.
Remove the large white warranty sticker from the metal frame to expose a screw.
Disconnect the optical drive data cable from the back of the optical drive.
Disconnect the power cable from the back of the optical drive.
Remove the single 11.3 mm gold T10 Torx screw from the hole marked "G."
16 farklı kişi bu kılavuzu tamamladı.
