Ana içeriğe geç
Xbox 360 S Hard Drive Replacement
  1. Xbox 360 S Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 1. Xbox 360 S Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 2. Xbox 360 S Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 3.
    • Orient the Xbox 360 S so that the bottom of the console is facing toward you.
    • Push the latch holding down the hard drive cover to the left.
    • Pull the hard drive cover away from the console.
  2. Xbox 360 S Hard Drive Replacement: adım 2, 3 resimden 1. Xbox 360 S Hard Drive Replacement: adım 2, 3 resimden 2. Xbox 360 S Hard Drive Replacement: adım 2, 3 resimden 3.
    • Firmly grasp the fabric tab labeled "250 GB" attached to the hard drive.
    • Pull the hard drive straight out of the console.
    • The fabric tab is attached to a catch further inside the hard drive housing. It will take some force to pull the hard drive out.
Sonuç
96 farklı kişi bu kılavuzu tamamladı.
Brett Hartt
126.976 İtibar
143 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Community
136 Üyeler
15.157 adet Kılavuz yazıldı
4 Yorum
do you have to transfer the OS? or data? if so what utility is used? do you need a data transfer cable?
Can I just add an external drive to supplement the existing HDD?
David Johnson - Yanıt
no the os is on the internal drive all the hard drive is doing is adding more storge space
Nightwolf Gamer -
My hardrive says its unformated but its not and i dont want to loose content
Javier Eduardo Pacheco Hazim - Yanıt
Can I take the external out of the little black cover?
Lallie Cooney - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 18
Son 7 gün: 125
Son 30 gün: 601
Her zaman: 140,163
