Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Xbox 360 S Hard Drive Replacement
Neye ihtiyacın var
  1. Xbox 360 S Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 1. Xbox 360 S Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 2. Xbox 360 S Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 3.
    • Orient the Xbox 360 S so that the bottom of the console is facing toward you.
    • Push the latch holding down the hard drive cover to the left.
    • Pull the hard drive cover away from the console.
  2. Xbox 360 S Hard Drive Replacement: adım 2, 3 resimden 1. Xbox 360 S Hard Drive Replacement: adım 2, 3 resimden 2. Xbox 360 S Hard Drive Replacement: adım 2, 3 resimden 3.
    • Firmly grasp the fabric tab labeled "250 GB" attached to the hard drive.
    • Pull the hard drive straight out of the console.
    • The fabric tab is attached to a catch further inside the hard drive housing. It will take some force to pull the hard drive out.
    If i buy a new xbox 360 and replace the hardrive inside with my own, will i have my account and saves? or will i have to recover my account and start over?
    yamboboy - Yanıt
    You will still have your saves and account if you replace your hard drive in the new xbox
    Robert Miller -
    hola tengo un disco de laptop y quiero ponerle 100 juegos como puedo hacer la xbox me reconose el disco y todo lo configuro pero cuando conecto a mi pc para pasar los juejosel emulador no me deja
    Cesar Tourreilles - Yanıt
    My fabric was accidentally ripped off years ago. What do I do?
    org 2026 - Yanıt
    Stick another bit on there
    Josh Cool -
Sonuç
98 farklı kişi bu kılavuzu tamamladı.
Brett Hartt
127.982 İtibar
143 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
137 Üyeler
17.457 adet Kılavuz yazıldı
4 Yorum
do you have to transfer the OS? or data? if so what utility is used? do you need a data transfer cable?
Can I just add an external drive to supplement the existing HDD?
David Johnson - Yanıt
no the os is on the internal drive all the hard drive is doing is adding more storge space
Nightwolf Gamer -
My hardrive says its unformated but its not and i dont want to loose content
Javier Eduardo Pacheco Hazim - Yanıt
Can I take the external out of the little black cover?
Lallie Cooney - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 174
Son 30 gün: 717
Her zaman: 145,080
