Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
There is no such thing as too much hard drive space, and nothing more frustrating than too little. This guide will show you how to replace your Xbox 360 S hard drive.
Aletler
Hiçbir alet belirtilmedi.
  1. Orient the Xbox 360 S so that the bottom of the console is facing toward you. Push the latch holding down the hard drive cover to the left. Pull the hard drive cover away from the console.
    • Orient the Xbox 360 S so that the bottom of the console is facing toward you.
    • Push the latch holding down the hard drive cover to the left.
    • Pull the hard drive cover away from the console.
  2. Firmly grasp the fabric tab labeled "250 GB" attached to the hard drive. Pull the hard drive straight out of the console. The fabric tab is attached to a catch further inside the hard drive housing. It will take some force to pull the hard drive out.
    • Firmly grasp the fabric tab labeled "250 GB" attached to the hard drive.
    • Pull the hard drive straight out of the console.
    • The fabric tab is attached to a catch further inside the hard drive housing. It will take some force to pull the hard drive out.
Sonuç
87 farklı kişi bu kılavuzu tamamladı.
Brett Hartt
120.748 İtibar
143 adet Kılavuz yazıldı
Takım
iFixit iFixit üyesi
Community
135 Üyeler
15.083 adet Kılavuz yazıldı
4 Yorum
do you have to transfer the OS? or data? if so what utility is used? do you need a data transfer cable?
Can I just add an external drive to supplement the existing HDD?
David Johnson - Yanıt
no the os is on the internal drive all the hard drive is doing is adding more storge space
Nightwolf Gamer -
10100101001011001010101010010111111111111111101001010010101010101001000101001011001010
allloa - Yanıt
My hardrive says its unformated but its not and i dont want to loose content
Javier Eduardo Pacheco Hazim - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 52
Son 30 gün: 273
Her zaman: 126,845
