Neye ihtiyacın var
In order to get to the laser to replace it you first have to remove the disk drive.
The link at the top is an IFIXIT guide that helps you to remove and replace the optical disk drive.
Now that you have completed steps 1 and 2
Remove the elastic band on the disk drive.
Use the spudger's flat side to get under the biggest plastic pin on edge of the board.
Push the pin backwards and off of the board.
Using your spudger again, push the second smaller pin backwards and off of the board.
Then, slide the board away from the pin slightly to be free of the last plastic element (the black corner thing).
If you followed all the steps you should have a working XBOX 360 S.
7 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Thanks, took me around 30 min to do this. Everything is written in detail. I like that.
