Neye ihtiyacın var
In order to get to the laser to replace it you first have to remove the disk drive.
The link at the top is an IFIXIT guide that helps you to remove and replace the optical disk drive.
Now that you have completed steps 1 and 2
Remove the elastic band on the disk drive.
With the underside exposed, identity the 4 main screws.
Remove these 4 screws.
Remove the cover to expose the assembly
You first have to detach the foam on the front in order to take the cover off because the foam is gluing the two halves together. Just slide a spudger underneath it along the bottom and sides, making sure you're actually going underneath it and not tearing it.
Locate the three ribbons connected to the board.
Use the plastic spudger to unclamp the ribbons from the board.
For the smaller two cables, push the brown plastic piece away from the white piece to release. For the bigger cable, the brown piece is on a small hinge and you need to rotate it towards the white piece to release.
Use the spudger's flat side to get under the biggest plastic pin on edge of the board.
Push the pin backwards and off of the board.
Using your spudger again, push the second smaller pin backwards and off of the board.
Then, slide the board away from the pin slightly to be free of the last plastic element (the black corner thing).
Connect the ribbon to the replacement lens by sliding it in place then closing the plastic fastener.
Place the removed metal fastener on the new laser lens and use the removed screw to secure the fastener to the replacement lens.
The lens has strong magnets in it that will attract the screw unless you're using a magnetic screwdriver of the exact right size. I also had to tape the back of the lens to the table so it didn't move, as well as tape the bracket in the right place.
If you followed all the steps you should have a working XBOX 360 S.
7 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Thanks, took me around 30 min to do this. Everything is written in detail. I like that.
