Giriş
Use this guide to remove the gray plastic top vent from your Xbox 360.
Neye ihtiyacın var
Grasp the hard drive assembly and press the release button while lifting its front edge.
Remove the hard drive assembly from the top vent.
The top vent is secured to the console via clips. The first two clips are located underneath the top vent closest to the faceplate, as shown in the pictures.
39 farklı kişi bu kılavuzu tamamladı.
WARNING: Just replacing the drive will not make it work correctly. Microsoft has married the drives to the motherboard. Hence, in order to get full operation out of the drive you'll have to perform more steps not listed here. Search in the FAQ on this specific topic for more details. Otherwise, before buying a new drive, try cleaning the inside of the old one and/or replace the belt involved in opening and closing the drive door.
- Good Luck
Eric - Yanıt
Thanks..helped!
joseph zulu - Yanıt
bress the button and lift with the same hand! i thought mine was stuck because of this pic!!!
Maths with Luigi - Yanıt
