Giriş
Steady your aim by replacing the analog stick grips on the Xbox 360 wireless controller.
Neye ihtiyacın var
Depress the battery release button on the top of the controller.
Remove the battery holder from the controller.
Bu adımda kullanılan alet:Tweezers$4.99
Use a pair of tweezers to peel the barcode sticker from the battery compartment.
Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
Lift the vibration motor out of the front case.
Lifting from the headphone jack and power plug, remove the logic board from the front case.
Grasp the right analog stick and pull the cover off its mount peg.
101 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
unnecessary steps.
3 steps:
remove all 7 screws.
flip upside down remove top plate
pull stick caps off
reinstall in reverse.
you may have to slide the vibration motors into the slots on the top half when putting back together.
