Ana içeriğe geç
Xbox 360 Wireless Controller Front Case Replacement
Neye ihtiyacın var
    1. Xbox 360 Wireless Controller Front Case Replacement, Battery: adım 1, 2 resimden 1. Xbox 360 Wireless Controller Front Case Replacement, Battery: adım 1, 2 resimden 2.
      • Depress the battery release button on the top of the controller.
      • Remove the battery holder from the controller.
      • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
      FixBot'a Sor
      Yorum Ekle
    1. Xbox 360 Wireless Controller Front Case Replacement, Rear Case: adım 2, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
      FixBot'a Sor
      Yorum Ekle
    2. Xbox 360 Wireless Controller Front Case Replacement: adım 3, 1 resimden 1.
      • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
      FixBot'a Sor
      Yorum Ekle
    3. Xbox 360 Wireless Controller Front Case Replacement: adım 4, 2 resimden 1. Xbox 360 Wireless Controller Front Case Replacement: adım 4, 2 resimden 2.
      Spudger
      $2.99
      • Insert a Spudger between the front and rear cases along the left edge of the controller.
      • Rotate the spudger toward the front of the controller, prying the two cases apart.
      FixBot'a Sor
      Yorum Ekle
    4. Xbox 360 Wireless Controller Front Case Replacement: adım 5, 2 resimden 1. Xbox 360 Wireless Controller Front Case Replacement: adım 5, 2 resimden 2.
      • Insert a spudger between the front and rear cases, near the headphone jack.
      • Rotate the spudger toward the front of the controller to pry the two cases apart.
      FixBot'a Sor
      Yorum Ekle
    5. Xbox 360 Wireless Controller Front Case Replacement: adım 6, 2 resimden 1. Xbox 360 Wireless Controller Front Case Replacement: adım 6, 2 resimden 2.
      • Grasp the controller by the battery compartment and the headphone jack.
      • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
      • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
      FixBot'a Sor
      Yorum Ekle
    1. Xbox 360 Wireless Controller Front Case Replacement, Vibration Motors: adım 7, 2 resimden 1. Xbox 360 Wireless Controller Front Case Replacement, Vibration Motors: adım 7, 2 resimden 2.
      • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
      • Lift the vibration motor out of the front case.
      FixBot'a Sor
      Yorum Ekle
    2. Xbox 360 Wireless Controller Front Case Replacement: adım 8, 2 resimden 1. Xbox 360 Wireless Controller Front Case Replacement: adım 8, 2 resimden 2.
      • Remove the vibration motor from the other side of the controller using the same method previously described.
      • The left motor has significantly more counterweight than the right motor.
      FixBot'a Sor
      Yorum Ekle
    1. Xbox 360 Wireless Controller Front Case Replacement, Logic Board: adım 9, 2 resimden 1. Xbox 360 Wireless Controller Front Case Replacement, Logic Board: adım 9, 2 resimden 2.
      • Lifting from the headphone jack and power plug, remove the logic board from the front case.
      FixBot'a Sor
      Yorum Ekle
    1. Xbox 360 Wireless Controller Front Case Replacement, Bottom Panel: adım 10, 2 resimden 1. Xbox 360 Wireless Controller Front Case Replacement, Bottom Panel: adım 10, 2 resimden 2.
      • Lift the bumper panel off of the front case.
      FixBot'a Sor
      Yorum Ekle
    2. Xbox 360 Wireless Controller Front Case Replacement: adım 11, 1 resimden 1.
      • Remove the rubber pad from the back of the D-pad.
      FixBot'a Sor
      Yorum Ekle
    3. Xbox 360 Wireless Controller Front Case Replacement: adım 12, 1 resimden 1.
      • Remove the two 7.0 mm silver Phillips screws from the back of the D-pad.
      FixBot'a Sor
      Yorum Ekle
    4. Xbox 360 Wireless Controller Front Case Replacement: adım 13, 2 resimden 1. Xbox 360 Wireless Controller Front Case Replacement: adım 13, 2 resimden 2.
      • The D-pad is secured to its backing by two diagonal clips, shown in red.
      • Use a pair of tweezers and squeeze the clips together to release the D-pad from its backing.
      FixBot'a Sor
      Yorum Ekle
    5. Xbox 360 Wireless Controller Front Case Replacement: adım 14, 2 resimden 1. Xbox 360 Wireless Controller Front Case Replacement: adım 14, 2 resimden 2.
      • Lift the D-pad backing out of its compartment on the front case.
      • The D-pad remains below the front case.
      • The D-pad will fall once its backing is removed. Be sure to support it as you remove the backing.
      • The backing is slotted to its compartment to ensure that it will always be aligned properly.
      FixBot'a Sor
      Yorum Ekle
    6. Xbox 360 Wireless Controller Front Case Replacement: adım 15, 1 resimden 1.
      • Remove the rubber pad from the back of the input buttons.
      FixBot'a Sor
      Yorum Ekle
    7. Xbox 360 Wireless Controller Front Case Replacement: adım 16, 2 resimden 1. Xbox 360 Wireless Controller Front Case Replacement: adım 16, 2 resimden 2.
      • Using a pair or tweezers, remove the following buttons from the front panel:
      • A Button
      • B Button
      • X Button
      • Y Button
      • Start Button
      • Select Button
      • Guide Button
      FixBot'a Sor
      Yorum Ekle
    8. Xbox 360 Wireless Controller Front Case Replacement: adım 17, 1 resimden 1.
      • Using a pair of tweezers, remove the LED ring from the front panel.
      FixBot'a Sor
      Yorum Ekle
    9. Xbox 360 Wireless Controller Front Case Replacement: adım 18, 3 resimden 1. Xbox 360 Wireless Controller Front Case Replacement: adım 18, 3 resimden 2. Xbox 360 Wireless Controller Front Case Replacement: adım 18, 3 resimden 3.
      • Insert a spudger between the lower panel and front case.
      • Slide the spudger along the gap between the two case components.
      • Lift the lower panel off of the front case.
      FixBot'a Sor
      Yorum Ekle
Sonuç
19 farklı kişi bu kılavuzu tamamladı.
Brett Hartt
132.296 İtibar
144 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
49.878 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 72
Her zaman: 14,168
