Ana içeriğe geç
Xbox Controller S Buttons Replacement Guide
Neye ihtiyacın var
  1. Xbox Controller S Buttons Replacement Guide, Backplate: adım 1, 2 resimden 1. Xbox Controller S Buttons Replacement Guide, Backplate: adım 1, 2 resimden 2.
    • Remove the six visible 8mm Phillips screws with a #1 Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Xbox Controller S Buttons Replacement Guide: adım 2, 2 resimden 1. Xbox Controller S Buttons Replacement Guide: adım 2, 2 resimden 2.
    • Peel back the barcode sticker to reveal the seventh Phillips screw and remove it.
    FixBot'a Sor
    Yorum Ekle
  3. Xbox Controller S Buttons Replacement Guide: adım 3, 3 resimden 1. Xbox Controller S Buttons Replacement Guide: adım 3, 3 resimden 2. Xbox Controller S Buttons Replacement Guide: adım 3, 3 resimden 3.
    • Carefully lift the backplate off of the controller.
    • Make sure to hold the frontplate to prevent the buttons from falling out.
    FixBot'a Sor
    Yorum Ekle
  4. Xbox Controller S Buttons Replacement Guide, Vibration Motors: adım 4, 3 resimden 1. Xbox Controller S Buttons Replacement Guide, Vibration Motors: adım 4, 3 resimden 2. Xbox Controller S Buttons Replacement Guide, Vibration Motors: adım 4, 3 resimden 3.
    • Unplug the two vibration motors and lift them out of the case, being sure not to pull on the wires.
    FixBot'a Sor
    Yorum Ekle
  5. Xbox Controller S Buttons Replacement Guide, Logic Board: adım 5, 2 resimden 1. Xbox Controller S Buttons Replacement Guide, Logic Board: adım 5, 2 resimden 2.
    • Lift the logic board out of the controller.
    FixBot'a Sor
    Yorum Ekle
  6. Xbox Controller S Buttons Replacement Guide, Rubber Pads: adım 6, 3 resimden 1. Xbox Controller S Buttons Replacement Guide, Rubber Pads: adım 6, 3 resimden 2. Xbox Controller S Buttons Replacement Guide, Rubber Pads: adım 6, 3 resimden 3.
    • Remove the rubber pads.
    FixBot'a Sor
    Yorum Ekle
  7. Xbox Controller S Buttons Replacement Guide, Buttons: adım 7, 3 resimden 1. Xbox Controller S Buttons Replacement Guide, Buttons: adım 7, 3 resimden 2. Xbox Controller S Buttons Replacement Guide, Buttons: adım 7, 3 resimden 3.
    • Remove the A, B, X, Y, White, and Black buttons with a pair of tweezers.
    • Remove the Back and Start buttons.
    • When putting the buttons back in, make sure to align the notches with the case.
    FixBot'a Sor
    Yorum Ekle
  8. Xbox Controller S Buttons Replacement Guide, D-Pad: adım 8, 3 resimden 1. Xbox Controller S Buttons Replacement Guide, D-Pad: adım 8, 3 resimden 2. Xbox Controller S Buttons Replacement Guide, D-Pad: adım 8, 3 resimden 3.
    • Unscrew the the two 7mm Phillips screws.
    • Separate the D-pad by pushing the two clips in with a pair of tweezers.
    FixBot'a Sor
    Yorum Ekle
  9. Xbox Controller S Buttons Replacement Guide: adım 9, 1 resimden 1.
    • Separate the two halves of the D-pad.
    • The front half of the D-pad will fall when you take the back half out, be sure to catch it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order, being careful to line everything back up.
burntpizza
169 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 37
Her zaman: 347
