Ana içeriğe geç
Xbox Disassembly
Neye ihtiyacın var
Videoya Genel Bakış
  1. Xbox Disassembly, Xbox Disassembly: adım 1, 1 resimden 1.
    • Start with your Xbox unplugged and sitting on a flat, stable surface.
    FixBot'a Sor
    Yorum Ekle
  2. Xbox Disassembly: adım 2, 1 resimden 1.
    • Flip the Xbox over and pry off the rubber feet with a metal spudger.
    FixBot'a Sor
    Yorum Ekle
  3. Xbox Disassembly: adım 3, 2 resimden 1. Xbox Disassembly: adım 3, 2 resimden 2.
    • Peel back both the silver sticker and the white barcode sticker to reveal two additional screws.
    FixBot'a Sor
    Yorum Ekle
  4. Xbox Disassembly: adım 4, 1 resimden 1.
    • Use a T20 Torx screwdriver to remove the four screws located under the rubber feet you just removed as well as the two screws from beneath the stickers removed in the previous step.
    FixBot'a Sor
    Yorum Ekle
  5. Xbox Disassembly: adım 5, 2 resimden 1. Xbox Disassembly: adım 5, 2 resimden 2.
    • Once the bottom shell is no longer attached, carefully turn the Xbox right-side-up and lift off the top shell.
    FixBot'a Sor
    Yorum Ekle
  6. Xbox Disassembly: adım 6, 2 resimden 1. Xbox Disassembly: adım 6, 2 resimden 2.
    • Move the grey ribbon cable out of the way in order to remove the three 3 mm screws using T10 Torx screwdriver. They are located on the upper right corner, lower right, and lower left corners of disk drive.
    • The screw on the lower left corner of the disk drive is not in the hole that it appears to be in, but rather just closer to the corner.
    FixBot'a Sor
    Yorum Ekle
  7. Xbox Disassembly: adım 7, 2 resimden 1. Xbox Disassembly: adım 7, 2 resimden 2.
    • Lift the hard drive storage unit out of the Xbox. It should come right out.
    • Take the power cable out of the track around the hard drive so that the unit will come out easier.
    FixBot'a Sor
    Yorum Ekle
  8. Xbox Disassembly: adım 8, 3 resimden 1. Xbox Disassembly: adım 8, 3 resimden 2. Xbox Disassembly: adım 8, 3 resimden 3.
    • Use a T15 Torx screwdriver to remove four 3.37mm screws from both sides of the hard drive.
    • Remove the plastic housing from the hard drive. It does have some clips on it, but it should come right off.
    FixBot'a Sor
    Yorum Ekle
  9. Xbox Disassembly: adım 9, 2 resimden 1. Xbox Disassembly: adım 9, 2 resimden 2.
    • Unplug both the ribbon cable and power cable from hard drive.
    • They are in there pretty tightly, so this may take some effort.
    FixBot'a Sor
    Yorum Ekle
  10. Xbox Disassembly: adım 10, 3 resimden 1. Xbox Disassembly: adım 10, 3 resimden 2. Xbox Disassembly: adım 10, 3 resimden 3.
    • Remove the disk drive. It should come right out.
    • Unplug the ribbon cable and yellow cables from back of disk drive.
    FixBot'a Sor
    Yorum Ekle
  11. Xbox Disassembly: adım 11, 1 resimden 1.
    • Pry back the black plastic tabs around the disk drive in order to remove it from its housing. Once removed, set the drive aside.
    FixBot'a Sor
    Yorum Ekle
  12. Xbox Disassembly: adım 12, 1 resimden 1.
    • Unplug the multi-colored power cord from the motherboard. It can be plugged in very tight, so it may take some effort to unplug it.
    FixBot'a Sor
    Yorum Ekle
  13. Xbox Disassembly: adım 13, 2 resimden 1. Xbox Disassembly: adım 13, 2 resimden 2.
    • Using T10 Torx screwdriver, remove two 3mm screws from the power supply board.
    FixBot'a Sor
    Yorum Ekle
  14. Xbox Disassembly: adım 14, 2 resimden 1. Xbox Disassembly: adım 14, 2 resimden 2.
    • Remove the power supply and set it aside. It should lift right out.
    FixBot'a Sor
    Yorum Ekle
  15. Xbox Disassembly: adım 15, 2 resimden 1. Xbox Disassembly: adım 15, 2 resimden 2.
    • Unplug the bundle of yellow cables as well as the rainbow cord from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  16. Xbox Disassembly: adım 16, 2 resimden 1. Xbox Disassembly: adım 16, 2 resimden 2.
    • Remove eleven 3mm screws from motherboard, using a T10 Torx screwdriver. Refer to the picture to find all eleven.
    • Unplug the power cable attached to the fan.
    FixBot'a Sor
    Yorum Ekle
  17. Xbox Disassembly: adım 17, 1 resimden 1.
    • Remove the motherboard from the Xbox. As long as all of the screws are out and the fan is disconnected, it will lift out easily.
    FixBot'a Sor
    Yorum Ekle
  18. Xbox Disassembly: adım 18, 1 resimden 1.
    • Pry the plastic fan clips away from the fan base and remove the fan.
    • This may take a little effort, as the clips are pretty stiff. Beware, the fan will be filthy.
    FixBot'a Sor
    Yorum Ekle
  19. Xbox Disassembly: adım 19, 2 resimden 1. Xbox Disassembly: adım 19, 2 resimden 2.
    • Using a T10 Torx screwdriver, remove two 3mm screws from each of two controller sockets.
    • Take the sockets out by pulling back and up at the same time.
    FixBot'a Sor
    Yorum Ekle
  20. Xbox Disassembly: adım 20, 1 resimden 1.
    • Congratulations, your Xbox is now completely dismembered.
    FixBot'a Sor
    Yorum Ekle
Sonuç
57 farklı kişi bu kılavuzu tamamladı.
rmarstel
6.273 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-2, Maness Fall 2009 Cal Poly, Team 18-2, Maness Fall 2009 üyesi
CPSU-MANESS-F09S18G2
3 Üyeler
26 adet Kılavuz yazıldı
10Kılavuz Yorumları
Awesomeness, thanks a lot!
godoyander - Yanıt Paylaş
Thanks a million - perfect!
xan_lucky16 - Yanıt Paylaş
Heatsink removal?
Matt Russell - Yanıt Paylaş
Face plate removal?
Herberth Alvarez - Yanıt Paylaş
Did a complete cleanup and refresh of my Xbox thanks to your guide, thank you :)
Mickaël STEMMER - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 43
Son 7 gün: 339
Son 30 gün: 1,557
Her zaman: 223,472
