Ana içeriğe geç
Xbox Duke Controller Face Buttons Replacement
Neye ihtiyacın var
    1. Xbox Duke Controller Face Buttons Replacement, Face Plate: adım 1, 3 resimden 1. Xbox Duke Controller Face Buttons Replacement, Face Plate: adım 1, 3 resimden 2. Xbox Duke Controller Face Buttons Replacement, Face Plate: adım 1, 3 resimden 3.
      • Remove the seven black 8 mm screws holding the two halves of the Duke together using a Phillips #1 screwdriver.
      • To reach the deeply set screws, use a longer screw driver or a 4.0 socket bit in addition to the PH1 bit.
      FixBot'a Sor
      Yorum Ekle
    2. Xbox Duke Controller Face Buttons Replacement: adım 2, 3 resimden 1. Xbox Duke Controller Face Buttons Replacement: adım 2, 3 resimden 2. Xbox Duke Controller Face Buttons Replacement: adım 2, 3 resimden 3.
      • Remove the two halves of the Duke, placing the top plate face-down so the buttons don't fall out.
      FixBot'a Sor
      Yorum Ekle
    1. Xbox Duke Controller Face Buttons Replacement, Face Buttons: adım 3, 3 resimden 1. Xbox Duke Controller Face Buttons Replacement, Face Buttons: adım 3, 3 resimden 2. Xbox Duke Controller Face Buttons Replacement, Face Buttons: adım 3, 3 resimden 3.
      • Remove the silicone pads and pull out the directional pad assembly.
      FixBot'a Sor
      Yorum Ekle
    2. Xbox Duke Controller Face Buttons Replacement: adım 4, 3 resimden 1. Xbox Duke Controller Face Buttons Replacement: adım 4, 3 resimden 2. Xbox Duke Controller Face Buttons Replacement: adım 4, 3 resimden 3.
      • Using a plastic opening tool, remove the plastic plate from the bottom of the directional pad assembly.
      • Pull out the silicone pad.
      FixBot'a Sor
      Yorum Ekle
    3. Xbox Duke Controller Face Buttons Replacement: adım 5, 2 resimden 1. Xbox Duke Controller Face Buttons Replacement: adım 5, 2 resimden 2.
      • Remove the silicone pads from the top plate of the controller and remove all of the face buttons.
      • To replace the buttons, line them up with the grooves in the top plate.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Anthony Casino
642 İtibar
4 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 42
Her zaman: 446
