Ana içeriğe geç
Xbox Duke Controller Potentiometer Replacement
Neye ihtiyacın var
  1. Xbox Duke Controller Potentiometer Replacement, Face Plate: adım 1, 3 resimden 1. Xbox Duke Controller Potentiometer Replacement, Face Plate: adım 1, 3 resimden 2. Xbox Duke Controller Potentiometer Replacement, Face Plate: adım 1, 3 resimden 3.
    • Remove the seven black 8 mm screws holding the two halves of the Duke together using a Phillips #1 screwdriver.
    • To reach the deeply set screws, use a longer screw driver or a 4.0 socket bit in addition to the PH1 bit.
  2. Xbox Duke Controller Potentiometer Replacement: adım 2, 3 resimden 1. Xbox Duke Controller Potentiometer Replacement: adım 2, 3 resimden 2. Xbox Duke Controller Potentiometer Replacement: adım 2, 3 resimden 3.
    • Remove the two halves of the Duke, placing the top plate face-down so the buttons don't fall out.
  3. Xbox Duke Controller Potentiometer Replacement, Potentiometer: adım 3, 2 resimden 1. Xbox Duke Controller Potentiometer Replacement, Potentiometer: adım 3, 2 resimden 2.
    • Remove the stick caps from the potentiometers.
  4. Xbox Duke Controller Potentiometer Replacement: adım 4, 2 resimden 1. Xbox Duke Controller Potentiometer Replacement: adım 4, 2 resimden 2.
    • Disconnect the connectors attaching the rumble motors to the motherboard using a pair of tweezers.
    • Be gentle when slipping the tweezers underneath the flaps of the connectors; they are fragile and can snap.
  5. Xbox Duke Controller Potentiometer Replacement: adım 5, 2 resimden 1. Xbox Duke Controller Potentiometer Replacement: adım 5, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the four yellow 8 mm screws holding the motherboard to the bottom half of the controller.
  6. Xbox Duke Controller Potentiometer Replacement: adım 6, 2 resimden 1. Xbox Duke Controller Potentiometer Replacement: adım 6, 2 resimden 2.
    • Remove the motherboard from the bottom half of the controller.
  7. Xbox Duke Controller Potentiometer Replacement: adım 7, 3 resimden 1. Xbox Duke Controller Potentiometer Replacement: adım 7, 3 resimden 2. Xbox Duke Controller Potentiometer Replacement: adım 7, 3 resimden 3.
    • Desolder the connector pins holding the left trigger assembly in place.
    • Remove the trigger assembly by pushing on the black connectors that hold them to the motherboard.
  8. Xbox Duke Controller Potentiometer Replacement: adım 8, 1 resimden 1.
    • Desolder all of the connector pins holding the potentiometer in place.
    • Pull out the potentiometers and solder the new ones into place.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Anthony Casino
630 İtibar
4 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 51
Her zaman: 359
