Ana içeriğe geç
Xbox Intec 7.2" Color Game Screen Disassembly
Neye ihtiyacın var
  1. Xbox Intec 7.2" Color Game Screen Disassembly, Intec 7.2" Color Game Screen: adım 1, 2 resimden 1. Xbox Intec 7.2" Color Game Screen Disassembly, Intec 7.2" Color Game Screen: adım 1, 2 resimden 2.
    • Top shell is held in place with 4 screws and 6 retaining tabs
    • Remove 2 rubber pads to uncover 2 hidden screws
    • Remove 4 #1 screws
    FixBot'a Sor
    Yorum Ekle
  2. Xbox Intec 7.2" Color Game Screen Disassembly: adım 2, 2 resimden 1. Xbox Intec 7.2" Color Game Screen Disassembly: adım 2, 2 resimden 2.
    • Take a spudger and disengage the 6 retaining tabs
    • This will be the most time-consuming step. Be patient and take your time.
    • You will hear an audible pop when disengaging the tabs.
    • Remove top housing
    FixBot'a Sor
    Yorum Ekle
  3. Xbox Intec 7.2" Color Game Screen Disassembly: adım 3, 2 resimden 1. Xbox Intec 7.2" Color Game Screen Disassembly: adım 3, 2 resimden 2.
    • Remove 2 #1 screws
    • Disconnect 4 wire harnesses
    FixBot'a Sor
    Yorum Ekle
  4. Xbox Intec 7.2" Color Game Screen Disassembly: adım 4, 3 resimden 1. Xbox Intec 7.2" Color Game Screen Disassembly: adım 4, 3 resimden 2. Xbox Intec 7.2" Color Game Screen Disassembly: adım 4, 3 resimden 3.
    • Disconnect speaker header
    • It's not necessary to remove the speakers from the housing unless you need to.
    • Disconnect header if speakers need to be removed. Otherwise, this will be done in the next step.
    • Remove 8 #1 screws
    FixBot'a Sor
    Yorum Ekle
  5. Xbox Intec 7.2" Color Game Screen Disassembly: adım 5, 2 resimden 1. Xbox Intec 7.2" Color Game Screen Disassembly: adım 5, 2 resimden 2.
    • Disconnect 2 headers
    • Lift wires over retaining posts
    FixBot'a Sor
    Yorum Ekle
  6. Xbox Intec 7.2" Color Game Screen Disassembly: adım 6, 2 resimden 1. Xbox Intec 7.2" Color Game Screen Disassembly: adım 6, 2 resimden 2.
    • Grab the edges of the board and lift up
    • Don't attempt to fully remove the board from the unit yet
    • Disconnect last header
    FixBot'a Sor
    Yorum Ekle
  7. Xbox Intec 7.2" Color Game Screen Disassembly: adım 7, 1 resimden 1.
    • It's not necessary to remove the screen from the housing unless you need to.
    • Remove 4 #1 screws to remove screen
    FixBot'a Sor
    Yorum Ekle
  8. Xbox Intec 7.2" Color Game Screen Disassembly: adım 8, 2 resimden 1. Xbox Intec 7.2" Color Game Screen Disassembly: adım 8, 2 resimden 2.
    • Lift up on tab
    • Remove 3 #1 screws
    • Grab the edges and lift the board up
    FixBot'a Sor
    Yorum Ekle
  9. Xbox Intec 7.2" Color Game Screen Disassembly: adım 9, 1 resimden 1.
    • Feed wires through the hinge enough to remove board from unit
    • These 4 headers are soldered directly to the board
    • If this board needs to be entirely removed, feed the wires all the way through the hinge.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Navy Vet 2015
8.267 İtibar
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 58
Her zaman: 1,512
