Ana içeriğe geç
Xbox One Elite Controller (Model 1698) Daughterboard Replacement
Neye ihtiyacın var
  1. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Show me the Screws!: adım 1, 2 resimden 1. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Show me the Screws!: adım 1, 2 resimden 2.
    • You can remove the side panels with a pry tool.
    • You don't need to remove the rubber. The rubber on this controller was already bad.
  2. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Removing the back panel screws: adım 2, 1 resimden 1.
    • Remove the 5 Torx Security Bit (TR9) screws.
  3. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Popping that back panel off: adım 3, 3 resimden 1. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Popping that back panel off: adım 3, 3 resimden 2. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Popping that back panel off: adım 3, 3 resimden 3.
    • Pry the panel next to the 3.5mm port.
    • Be careful to not rip the ribbon shown in the next step.
  4. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Warning Carefully remove the ribbon: adım 4, 2 resimden 1. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Warning Carefully remove the ribbon: adım 4, 2 resimden 2.
    • Be careful to not rip the ribbon cable.
    • You can pop the connector up to remove the ribbon easily.
    • Ribbon Cable
  5. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Screws on controller motherboard: adım 5, 1 resimden 1.
    • Remove the 2 Torx (T6) screws.
  6. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Desolder wires from motherboard: adım 6, 2 resimden 1. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Desolder wires from motherboard: adım 6, 2 resimden 2.
    • Desolder the 4 wires on each side, these control the vibrations and the RT LT.
  7. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the motherboard: adım 7, 2 resimden 1. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the motherboard: adım 7, 2 resimden 2.
    • Pull up from the "top" side of the controller on the daughterboard.
  8. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the Home Button Cover: adım 8, 3 resimden 1. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the Home Button Cover: adım 8, 3 resimden 2. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the Home Button Cover: adım 8, 3 resimden 3.
    • Be Careful to not lose the sync button.
    • Pry the middle section up from the home button side.
    • This will also remove the LB and RB which is a single part.
  9. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the controller daughterboard: adım 9, 2 resimden 1. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the controller daughterboard: adım 9, 2 resimden 2.
    • Unscrew the 6 Torx (T6) screws.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
EasyAsABC123
2.449 İtibar
5 adet Kılavuz yazıldı
1Rehber Yorum
Hola que tal amigo disculpa es posible sustituir esa misma placa por una de un mando one ?
tay redd - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 88
Her zaman: 9,170
