Ana içeriğe geç
Xbox One Elite Controller (Model 1698) LED Replacement
Neye ihtiyacın var
  1. Xbox One Elite Controller (Model 1698) LED Replacement, Show me the Screws!: adım 1, 2 resimden 1. Xbox One Elite Controller (Model 1698) LED Replacement, Show me the Screws!: adım 1, 2 resimden 2.
    • You can remove the side panels with a pry tool.
    • You don't need to remove the rubber. The rubber on this controller was already bad
  2. Xbox One Elite Controller (Model 1698) LED Replacement, Removing the back panel screws: adım 2, 1 resimden 1.
    • Remove the 5 Torx Security Bit (TR9) screws
    all the T8 screws on my controller have a clear filling in them, WTF?!?!?
    Patrick Henry - Yanıt
    all my T8 screws have a clear filling in them, WTF?!?!?!
    I've never seen that, I can't advise much other than scrapping it out with an xacto knife
    EasyAsABC123 - Yanıt
    My screws have a tiny metal pin in the center. Looks like I need a TR8 bit, not a T8. This might be what you are mistaking for a clear filling.
    Steve McGinn - Yanıt
    Thanks it might be TR8 i’ll update the guide
    While a TR8 will work, they’re actually TR9 screws on mine (Model 1698, X912908-004).
    Daniel - Yanıt
    @isbelldl thanks, updated to specify TR9
    TORX TR8 worked form the ifixit kit
    KRISTIAN KALLAWAY - Yanıt
    My anolog stick is lagging on my elite 1 controller. Can I remove a anolog module from a normal xbox 1 controller and then put into the elite 1 controller would it be compatible. I have all the soldering irons and stuff. It's only that I dont have any money and wanted to no if thay would work . Thanks guy appreciate your time kris
    kriswadd@hotmail.com - Yanıt
  3. Xbox One Elite Controller (Model 1698) LED Replacement, Popping that back panel off: adım 3, 3 resimden 1. Xbox One Elite Controller (Model 1698) LED Replacement, Popping that back panel off: adım 3, 3 resimden 2. Xbox One Elite Controller (Model 1698) LED Replacement, Popping that back panel off: adım 3, 3 resimden 3.
    • Pry the panel next to the 3.5mm port
    • Be careful to not rip the ribbon shown in the next step
  4. Xbox One Elite Controller (Model 1698) LED Replacement, Warning Carefully remove the ribbon: adım 4, 2 resimden 1. Xbox One Elite Controller (Model 1698) LED Replacement, Warning Carefully remove the ribbon: adım 4, 2 resimden 2.
    • Be careful to not rip the ribbon cable
    • You can pop the connector up to remove the ribbon easily
    • Ribbon Cable
    My connector did not look like this and popping it up broke it
    Amarokstar - Yanıt
    please post a picture of the connector so we can update this, you also might have a newer revision of the motherboard
    Is there any way to replace that connector bar or maybe an alternative to keeping the contacts down on the ribbon if it’s broken?
    Joe - Yanıt
    @joe you can try tape, or even hot glue (easy to remove with rubbing alcohol), that might hold it down. I wasn’t able to find the connector but i’m sure if you count the number of pins and measure it you’d be able to locate a replacement connector on something like mouser.
  5. Xbox One Elite Controller (Model 1698) LED Replacement, Screws on controller motherboard: adım 5, 1 resimden 1.
    • Remove the 2 Torx (T6) screws
  6. Xbox One Elite Controller (Model 1698) LED Replacement, Desolder wires from motherboard: adım 6, 2 resimden 1. Xbox One Elite Controller (Model 1698) LED Replacement, Desolder wires from motherboard: adım 6, 2 resimden 2.
    • Desolder the 4 wires on each side, these control the vibrations and the RT LT
    If you are just replacing the main power board there is no need to desolder at this point. The main power board can be removed with the controller board still in place.
    Malc Foy - Yanıt
  7. Xbox One Elite Controller (Model 1698) LED Replacement, Remove the motherboard: adım 7, 2 resimden 1. Xbox One Elite Controller (Model 1698) LED Replacement, Remove the motherboard: adım 7, 2 resimden 2.
    • Pull up from the "top" side of the controller on the sister board.
    Hi,
    I would like to know if I could get from you a Motherboard . In case you don' t have it, where could I find one?
    Thank you
    Alejandro Expósito - Yanıt
    Hi, I have 2 not working controllers (both 1698 and 1708). The 1708 broke the bumper switch, I manage to fix it but as always, postponed. So, can I either swap Xbox One Elite comtroller (1698) into Xbox One (1708) shell/housing or vice versa??
    Or can I mix both motherboard together so I can make one of them working?
    Fitifazrul Rahman - Yanıt
    It might work…it might damage one of the boards but probably wouldn’t
    EasyAsABC123 -
    I would like to buy a motherboard, can you please stock some up?
    davi_t - Yanıt
    I don’t work for ifixit, I don’t know if they see comments on a private made guide.
    EasyAsABC123 -
    I decided to toss all this stuff in the trash at this point as I am not going to spend +$50 on equipment and replacement parts to fix a $60 controller. But thanks for the educational manual all the same.
  8. Xbox One Elite Controller (Model 1698) LED Replacement, Remove the Home Button Cover: adım 8, 3 resimden 1. Xbox One Elite Controller (Model 1698) LED Replacement, Remove the Home Button Cover: adım 8, 3 resimden 2. Xbox One Elite Controller (Model 1698) LED Replacement, Remove the Home Button Cover: adım 8, 3 resimden 3.
    • Be Careful to not lose the sync button
    • Pry the middle section up from the home button side.
    • This will also remove the LB and RB which is a single part
  9. Xbox One Elite Controller (Model 1698) LED Replacement, Remove the controller daughterboard: adım 9, 2 resimden 1. Xbox One Elite Controller (Model 1698) LED Replacement, Remove the controller daughterboard: adım 9, 2 resimden 2.
    • Unscrew the 6 Torx (T6) screws
    On the 2nd picture: the D-pad dome switches are covered by a clear plastic film: is possible to remove it/reattach that plastic film? I believe there might be something stuck underneath the dome switches that’s interfering with the d-pad buttons working reliably/consistently. I know I could just replace the daughterboard, but I’m trying to avoid doing that if I can just clean it some how/find a way around it
    [deleted] - Yanıt
    This is just tacom tape :), feel free to buy more and replace
    Hi anyone know of where to find that rubber thing that goes on lb/rb trigger?
    kostas kazlauskas - Yanıt
    rubber thing? You mean the lb and rb part itself? or the home button section?
    EasyAsABC123 -
    The lb/rb white rubber behind the button supoort rubber i dont know how its called
    kostas kazlauskas -
  10. Xbox One Elite Controller (Model 1698) LED Replacement, Replace the LED: adım 10, 1 resimden 1.
    • Desolder the original LED from the motherboard of the controller. Do this for both sides of the LED until all of the old solder is removed.
    • Solder on your new LED.
    • Make sure it is installed the same direction as the old LED, or you can burn out the new LED.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
EasyAsABC123
2.407 İtibar
5 adet Kılavuz yazıldı
7 Yorum
So question I’m having troubles with my elite controller every time I go to plug it in and the charging port in the back of the controller it starts to smoke what’s my problem
Dustin Dykstra - Yanıt
It sounds like it could be a lot of things…
smoke is obvious a dead stop (stop plugging it in until you repair it).
I would first check the charge port and make sure it is firmly attached if it isn’t you can easily replace the usb port. Next it could be the mainboard charging circuit. if it is this…replace the controller is likely the ideal solution.
EasyAsABC123 -
I was looking to do this mod for fun. Do you have or know where I can get the led part number? A schematic or bom would be nice. Thanks
Clayton Armagost - Yanıt
0805 SMD LED Diode Lights
i bought these https://www.amazon.com/gp/product/B01CUG...
EasyAsABC123 -
Thank you. I ordered them so we will see what happens.
Clayton Armagost -
Worked like a champ. The original LED was a POS and melted when i applied the heat. I got it cleaned up and change with no other problem. Thanks for the guide.
Awesome I'm glad you had success!
EasyAsABC123 -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 30
Her zaman: 6,303
