Ana içeriğe geç
Xbox One Elite Controller (Model 1698) Motherboard Replacement
Neye ihtiyacın var
    1. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Show me the Screws!: adım 1, 2 resimden 1. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Show me the Screws!: adım 1, 2 resimden 2.
      • You can remove the side panels with a pry tool.
      • You don't need to remove the rubber. The rubber on this controller was already bad.
      FixBot'a Sor
      Yorum Ekle
    2. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Removing the back panel screws: adım 2, 1 resimden 1.
      • Remove the 5 Torx Security Bit (TR9) screws.
      FixBot'a Sor
      Yorum Ekle
    3. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Popping that back panel off: adım 3, 3 resimden 1. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Popping that back panel off: adım 3, 3 resimden 2. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Popping that back panel off: adım 3, 3 resimden 3.
      • Pry the panel next to the 3.5mm port.
      • Be careful to not rip the ribbon shown in the next step.
      FixBot'a Sor
      Yorum Ekle
    4. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Warning Carefully remove the ribbon: adım 4, 2 resimden 1. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Warning Carefully remove the ribbon: adım 4, 2 resimden 2.
      • Be careful to not rip the ribbon cable.
      • You can pop the connector up to remove the ribbon easily.
      • Ribbon Cable
      FixBot'a Sor
      Yorum Ekle
    5. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Screws on controller motherboard: adım 5, 1 resimden 1.
      • Remove the 2 Torx (T6) screws.
      FixBot'a Sor
      Yorum Ekle
    6. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Desolder wires from motherboard: adım 6, 2 resimden 1. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Desolder wires from motherboard: adım 6, 2 resimden 2.
      • Desolder the 4 wires on each side, these control the vibrations and the RT LT.
      FixBot'a Sor
      Yorum Ekle
    7. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Remove the motherboard: adım 7, 2 resimden 1. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Remove the motherboard: adım 7, 2 resimden 2.
      • Pull up from the "top" side of the controller on the daughterboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
EasyAsABC123
2.557 İtibar
5 adet Kılavuz yazıldı
1Rehber Yorum
50 minutes? half of that tops
glenn.fowell - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 23
Son 30 gün: 96
Her zaman: 19,380
