Giriş
Follow this guide to remove the hard drive from your Xbox One, and follow it in reverse to install a new drive.
Depending on the firmware version of your Xbox One, your console may or may not be able to format the replacement hard drive for you. Older firmwares cannot format the hard drive, while newer firmwares can.
If your Xbox One console is not capable of formatting a replacement hard drive, before you install your replacement drive, you will need to reformat the drive in a computer and install the necessary software, following this technique:
Neye ihtiyacın var
Videoya Genel Bakış
To open your Xbox, you're going to have to cut or peel up this tamper-evident tape. But don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
Use the flat end of a spudger to free the clips securing the front panel to the upper case.
Remove the front panel from the rest of the upper case.
Gently pull up on the speaker cable connector to disconnect it from the front panel board.
Use the flat end of a spudger to disconnect the antenna cable from the front panel board.
Disconnect the hard drive SATA power and data cables from the motherboard.
Remove the four 8.5 mm T10 Torx screws securing the hard drive assembly to the hard drive tray.
245 farklı kişi bu kılavuzu tamamladı.
90Kılavuz Yorumları
I've managed to open my Xbox one, tested the hard drive and it has failed (error scanned and it's 90% bad sectors). I've got a new harddrive for it, but can't find where to get the correct software for it/ how it needs to be formatted. You mention this info at the start of this repair but cant see a link to the software.
If there are no links, would cloning another xbox one harddrive work as a repair?
Ah, Sorted now. I managed to clone another hard drive. This doesn't work right off you still need to apply an update via a pend rive. But once this is done, the hard drive does pick up and work.
What Hard Drive did You Clone? My Hard Drive failed Aswell.
Please see my Xbox One HDD Replacement Wiki to solve your issue (scroll to very bottom): http://jw0914.github.io/Wikis/
JW0914 -
I haven't done this yet but I, like most other people won't want to lose any saved games etc. How do I do an exact copy from the current HDD to the SSD I'm putting in? Thanks!
