Ana içeriğe geç
Xbox One Kinect Colour Camera Replacement
Neye ihtiyacın var
  1. Xbox One Kinect Colour Camera Replacement, Outer Shell: adım 1, 1 resimden 1.
    • Remove the sticker on the underside of the device.
    • Remove the four 3.1x23.5 mm T10 screws underneath the sticker.
    • While you're at it, remove the four 3.1x7.5 mm T10 screws beneath the sticker. Make note of the sizes and locations of the screws.
  2. Xbox One Kinect Colour Camera Replacement: adım 2, 3 resimden 1. Xbox One Kinect Colour Camera Replacement: adım 2, 3 resimden 2. Xbox One Kinect Colour Camera Replacement: adım 2, 3 resimden 3.
    • Remove the back panel.
    • Remove the black panels on either side of the Kinect, and remove the 3.1x7.5mm T10 screws underneath them.
  3. Xbox One Kinect Colour Camera Replacement: adım 3, 3 resimden 1. Xbox One Kinect Colour Camera Replacement: adım 3, 3 resimden 2. Xbox One Kinect Colour Camera Replacement: adım 3, 3 resimden 3.
    • Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
    • Lift the internal assembly with the spudger.
    • Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
  4. Xbox One Kinect Colour Camera Replacement, Heat Sink Assembly: adım 4, 2 resimden 1. Xbox One Kinect Colour Camera Replacement, Heat Sink Assembly: adım 4, 2 resimden 2.
    • Remove the eight 2.9x7.6 mm T9 screws from the rear of the internal case.
    • Lift the internal metal case from the plastic shell enclosing the heat sink assembly.
  5. Xbox One Kinect Colour Camera Replacement: adım 5, 3 resimden 1. Xbox One Kinect Colour Camera Replacement: adım 5, 3 resimden 2. Xbox One Kinect Colour Camera Replacement: adım 5, 3 resimden 3.
    • Disconnect the ribbon cable between the sensor driver board and the motherboard.
    • Remove the 3.0x7.5 mm T9 screw holding the sensor driver board to the heat sink.
    • Remove the infrared sensor board for the Kinect.
  6. Xbox One Kinect Colour Camera Replacement: adım 6, 3 resimden 1. Xbox One Kinect Colour Camera Replacement: adım 6, 3 resimden 2. Xbox One Kinect Colour Camera Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Detach the ribbon cable leading to the microphone with the tweezers.
    • Remove the four 3.1x7.7 mm T9 screws connecting the microphone to the heat sink assembly.
    • Remove the stand.
  7. Xbox One Kinect Colour Camera Replacement: adım 7, 3 resimden 1. Xbox One Kinect Colour Camera Replacement: adım 7, 3 resimden 2. Xbox One Kinect Colour Camera Replacement: adım 7, 3 resimden 3.
    • Remove the eight 3.0x7.6 mm T9 screws from the motherboard.
    • Peel away the plastic film from the motherboard using the spudger.
    • Detach the ribbon cable leading to the color camera using the spudger.
  8. Xbox One Kinect Colour Camera Replacement: adım 8, 3 resimden 1. Xbox One Kinect Colour Camera Replacement: adım 8, 3 resimden 2. Xbox One Kinect Colour Camera Replacement: adım 8, 3 resimden 3.
    • Lift the motherboard and the heat sink assembly from the plastic shell. The components attached to the heat sink are now accessible.
  9. Xbox One Kinect Colour Camera Replacement, Colour Camera: adım 9, 3 resimden 1. Xbox One Kinect Colour Camera Replacement, Colour Camera: adım 9, 3 resimden 2. Xbox One Kinect Colour Camera Replacement, Colour Camera: adım 9, 3 resimden 3.
    • Go ahead and start by removing the Colour Camera's lens cap. This way you can remove the Camera without anything in your way.
  10. Xbox One Kinect Colour Camera Replacement: adım 10, 2 resimden 1. Xbox One Kinect Colour Camera Replacement: adım 10, 2 resimden 2.
    • Using the T5 screwdriver, remove the four 1.9x10.2 mm screws from the four corners of the camera.
    • With the spudger inserted in between the camera and the metal casing, carefully prop up the camera.
Sonuç
Malak Anshassi
338 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Hickman Fall 2014 USF Tampa, Team 1-3, Hickman Fall 2014 üyesi
USFT-HICKMAN-F14S1G3
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 1,995
