Ana içeriğe geç
Xbox One Kinect LED Sensor Replacement
Neye ihtiyacın var
  1. Xbox One Kinect LED Sensor Replacement, Outer Shell: adım 1, 1 resimden 1.
    • Remove the sticker on the underside of the device.
    • Remove the four 3.1x23.5 mm T10 screws underneath the sticker.
    • While you're at it, remove the four 3.1x7.5 mm T10 screws beneath the sticker. Make note of the sizes and locations of the screws.
  2. Xbox One Kinect LED Sensor Replacement: adım 2, 3 resimden 1. Xbox One Kinect LED Sensor Replacement: adım 2, 3 resimden 2. Xbox One Kinect LED Sensor Replacement: adım 2, 3 resimden 3.
    • Remove the back panel.
    • Remove the black panels on either side of the Kinect, and remove the 3.1x7.5mm T10 screws underneath them.
  3. Xbox One Kinect LED Sensor Replacement: adım 3, 3 resimden 1. Xbox One Kinect LED Sensor Replacement: adım 3, 3 resimden 2. Xbox One Kinect LED Sensor Replacement: adım 3, 3 resimden 3.
    • Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
    • Lift the internal assembly with the spudger.
    • Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
  4. Xbox One Kinect LED Sensor Replacement, Removing the LED Sensor: adım 4, 3 resimden 1. Xbox One Kinect LED Sensor Replacement, Removing the LED Sensor: adım 4, 3 resimden 2. Xbox One Kinect LED Sensor Replacement, Removing the LED Sensor: adım 4, 3 resimden 3.
    • Disconnect the ribbon cable between the sensor driver board and the motherboard.
    • Remove the 3.0x7.5 mm T9 screw holding the sensor driver board to the heat sink.
    • Remove the infrared sensor board for the Kinect.
Sonuç
Malak Anshassi
338 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Hickman Fall 2014 USF Tampa, Team 1-3, Hickman Fall 2014 üyesi
USFT-HICKMAN-F14S1G3
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 1,365
