Ana içeriğe geç
Xbox One Optical Drive Laser Replacement
Neye ihtiyacın var
  1. Xbox One Optical Drive Laser Replacement, Optical Drive Case Screws: adım 1, 1 resimden 1.
    • Make sure the optical drive is not connected to any power source and is powered off.
    • Unscrew the four Phillips #1 screws on the top of the optical drive.
  2. Xbox One Optical Drive Laser Replacement, Optical Drive Case Lid: adım 2, 1 resimden 1.
    • Lift the lid off of the optical drive case, this should require little to no force.
  3. Xbox One Optical Drive Laser Replacement, Optical Drive Case: adım 3, 2 resimden 1. Xbox One Optical Drive Laser Replacement, Optical Drive Case: adım 3, 2 resimden 2.
    • Slide the remaining optical drive case off of the internal components.
    • Internal components often snag on these points when removing the optical drive case.
  4. Xbox One Optical Drive Laser Replacement, ZIF Connectors: adım 4, 2 resimden 1. Xbox One Optical Drive Laser Replacement, ZIF Connectors: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Locate the three ZIF connectors on the optical drive PCB.
    • Using tweezers, gently lift the tab on each ZIF connector to release the ribbon cables.
    • Remove the ribbon cable from each ZIF connector.
  5. Xbox One Optical Drive Laser Replacement, PCB Screws: adım 5, 1 resimden 1.
    • Unscrew the three Phillips #0 screws mounting the PCB.
  6. Xbox One Optical Drive Laser Replacement, Moving the PCB: adım 6, 1 resimden 1.
    • Gently lift the PCB and place it to the side.
    • When lifting the PCB, be careful to not detach the wires connecting the PCB to the motor.
  7. Xbox One Optical Drive Laser Replacement, Optical Drive Laser Screws: adım 7, 1 resimden 1.
    • Unscrew the three Phillips #0 screws mounting the optical drive laser.
  8. Xbox One Optical Drive Laser Replacement, Optical Drive Laser: adım 8, 1 resimden 1.
    • Lift the old optical drive laser from the unit and place in the new optical drive laser.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Austin Stein
319 İtibar
1 Kılavuz yazıldı
2Kılavuz Yorumları
If my xbox one is reading Bluray disc(xbox one games/ Bluray movies), but for DVD it work sometimes, sometimes it wont (xbox 360 games/ DVD), should i replace the whole bluray drive or this Optical drive laser?
Ali Kazimi - Yanıt
I would start with this repair. A faulty laser sounds like a very likely source for your issue. If it doesn't work you have a problem with the drive board.
Replacing the entire drive would require you to replace the main motherboard of the Xbox with one from the same console that the replacement drive came from because they are linked as an anti-piracy measure. At that point you're better off replacing the entire console.
Austin Stein -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 54
Son 30 gün: 193
Her zaman: 8,068
