Ana içeriğe geç
Xbox One S Hard Drive Assembly
Neye ihtiyacın var
  1. Xbox One S Hard Drive Assembly, Case: adım 1, 1 resimden 1.
    • Flip the Xbox One S so that the bottom of the case is facing upward.
    FixBot'a Sor
    Yorum Ekle
  2. Xbox One S Hard Drive Assembly: adım 2, 1 resimden 1.
    • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
    FixBot'a Sor
    Yorum Ekle
  3. Xbox One S Hard Drive Assembly: adım 3, 1 resimden 1.
    • Once all of the clips are opened, remove the bottom part of the case.
    FixBot'a Sor
    Yorum Ekle
  4. Xbox One S Hard Drive Assembly: adım 4, 2 resimden 1. Xbox One S Hard Drive Assembly: adım 4, 2 resimden 2.
    • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
    FixBot'a Sor
    Yorum Ekle
  5. Xbox One S Hard Drive Assembly: adım 5, 2 resimden 1. Xbox One S Hard Drive Assembly: adım 5, 2 resimden 2.
    • Gently separate the interior case from the white exterior case using the appropriate method.
    • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield.
    FixBot'a Sor
    Yorum Ekle
  6. Xbox One S Hard Drive Assembly, Interior Case Top Panel: adım 6, 1 resimden 1.
    • Flip the interior case so it is fan side upward.
    FixBot'a Sor
    Yorum Ekle
  7. Xbox One S Hard Drive Assembly: adım 7, 1 resimden 1.
    • To access the hardware within the casing, you can pop and lift the top panel of the casing. It should come right off.
    FixBot'a Sor
    Yorum Ekle
  8. Xbox One S Hard Drive Assembly, Hard Drive Assembly: adım 8, 2 resimden 1. Xbox One S Hard Drive Assembly, Hard Drive Assembly: adım 8, 2 resimden 2.
    • To replace the hard drive, flip over the console and remove the two 10 mm T-10 Torx screws, C3 and C5, from the backside of the Xbox One S.
    • Some models may require C4 and C5.
    • This will allow the plastic casing surrounding the hard drive to become detached from the rest of the console.
    FixBot'a Sor
    Yorum Ekle
  9. Xbox One S Hard Drive Assembly: adım 9, 3 resimden 1. Xbox One S Hard Drive Assembly: adım 9, 3 resimden 2. Xbox One S Hard Drive Assembly: adım 9, 3 resimden 3.
    • Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies).
    FixBot'a Sor
    Yorum Ekle
Sonuç
19 farklı kişi bu kılavuzu tamamladı.
Victoria Law
1.126 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G3, Livingston Spring 2017 Cal Poly, Team S22-G3, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S22G3
4 Üyeler
59 adet Kılavuz yazıldı
2Kılavuz Yorumları
My F3 isn't coming out. The screwdriver isn't sitting tight like it is for the other ones. Any idea on how to fix that?
ben mccord - Yanıt Paylaş
Where is the guide to the replacing of hardrive to a HDD 3.5 instead of 2.5, I thought I found it on here but I have not been able to locate it since.
awesomedaisy - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 31
Son 30 gün: 216
Her zaman: 15,953
