Ana içeriğe geç
Xbox One S Power Block Replacement
Neye ihtiyacın var
  1. Xbox One S Power Block Replacement, Case: adım 1, 1 resimden 1.
    • Flip the Xbox One S so that the bottom of the case is facing upward.
    FixBot'a Sor
  2. Xbox One S Power Block Replacement: adım 2, 1 resimden 1.
    • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
    FixBot'a Sor
  3. Xbox One S Power Block Replacement: adım 3, 1 resimden 1.
    • Once all of the clips are opened, remove the bottom part of the case.
    FixBot'a Sor
  4. Xbox One S Power Block Replacement: adım 4, 2 resimden 1. Xbox One S Power Block Replacement: adım 4, 2 resimden 2.
    • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
    FixBot'a Sor
  5. Xbox One S Power Block Replacement: adım 5, 2 resimden 1. Xbox One S Power Block Replacement: adım 5, 2 resimden 2.
    • Gently separate the interior case from the white exterior case using the appropriate method.
    • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield.
    FixBot'a Sor
  6. Xbox One S Power Block Replacement, Hard Drive Assembly: adım 6, 2 resimden 1. Xbox One S Power Block Replacement, Hard Drive Assembly: adım 6, 2 resimden 2.
    • To replace the hard drive, flip over the console and remove the two 10 mm T-10 Torx screws, C3 and C5, from the backside of the Xbox One S.
    • Some models may require C4 and C5.
    • This will allow the plastic casing surrounding the hard drive to become detached from the rest of the console.
    FixBot'a Sor
  7. Xbox One S Power Block Replacement: adım 7, 3 resimden 1. Xbox One S Power Block Replacement: adım 7, 3 resimden 2. Xbox One S Power Block Replacement: adım 7, 3 resimden 3.
    • Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies).
    FixBot'a Sor
  8. Xbox One S Power Block Replacement, Optical Drive Assembly: adım 8, 1 resimden 1.
    • To remove the optical disc drive, remove the silver 10 mm T-10 Torx screw labeled "C4."
    FixBot'a Sor
  9. Xbox One S Power Block Replacement: adım 9, 1 resimden 1.
    • Pull the disc drive slightly off the motherboard and disconnect the plastic connectors from the motherboard.
    FixBot'a Sor
  10. Xbox One S Power Block Replacement, Motherboard: adım 10, 1 resimden 1.
    • To replace the motherboard you must remove the three silver 10 mm T-10 Torx screws labelled "C1," "C2," and "C6."
    • Remove the four black 8 mm T-8 Torx screws lablelled "A1," "A2," "A3," and "A4."
    FixBot'a Sor
  11. Xbox One S Power Block Replacement: adım 11, 1 resimden 1.
    • Locate the rectangular silver clamp on the opposite corner of the power block.
    • Remove the black bracket near the fan.
    FixBot'a Sor
  12. Xbox One S Power Block Replacement: adım 12, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Grab the clamp with the tweezers. Pull the clamp upward, away from the silver casing. Jiggle it back and forth like a tooth if necessary.
    • It's okay to apply a little bit of force here to get the clamp off the silver casing. The metal is bendable and can be bent/clamped back on.
    FixBot'a Sor
  13. Xbox One S Power Block Replacement, Remove Wifi antenna: adım 13, 1 resimden 1.
    • Remove the four black 8 mm T-9 Torx screws labeled "E1," "E2," "E3," and "E4."
    FixBot'a Sor
  14. Xbox One S Power Block Replacement, Remove Mediatek board: adım 14, 1 resimden 1.
    • Remove the three black 8 mm T-9 Torx screws labeled "D1," "D2," and "D3" to remove the Mediatek board.
    FixBot'a Sor
  15. Xbox One S Power Block Replacement: adım 15, 1 resimden 1.
    • Now that the clamp is removed, gently lift the motherboard from its edges out from the metal casing. The motherboard should come out with ease.
    FixBot'a Sor
  16. Xbox One S Power Block Replacement, Power Block: adım 16, 1 resimden 1.
    • Gently lift the power block off the motherboard
    FixBot'a Sor
  17. Xbox One S Power Block Replacement: adım 17, 1 resimden 1.
    • Locate the black connector that joins the power block to the motherboard.
    • The protruding rectangular part of the plastic connector, shown by the orange marker, is a locking tab.
    FixBot'a Sor
  18. Xbox One S Power Block Replacement: adım 18, 1 resimden 1.
    • Grab the connector as shown, pinch the small black locking tab, and pull firmly upward to detach the power block from the motherboard .
    FixBot'a Sor
Sonuç
49 farklı kişi bu kılavuzu tamamladı.
Erik Ramazzini
3.293 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G3, Livingston Spring 2017 Cal Poly, Team S22-G3, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S22G3
4 Üyeler
59 adet Kılavuz yazıldı
23Kılavuz Yorumları
So my Xbox One S isn’t turning on at all. No light, nothing. I went to take it apart and I plugged it in just to see if it would boot out of the blue. I turned it on and nothing happened but I can hear a faint clicking sound from the power supply. Does that mean, the power supply has gone bad, and I’ll need to replace it?
Cyology.IO - Yanıt Paylaş
yes because this xbox one s internal power supply is a fail.. look at there newer model the “xbox one x “ the internal powersupply of it has air ventilation coming from the upgraded version of the fan.
meaning the xbox one s power supply has no proper ventilation no air that blow the exhaust the heat will stuck up inside .. thats why it will not last longer .
the worst is that its design it self .. imagine when you accidentaly pour a water into the fan .. the water will go directly to the cpu and mobo.
that is why they upgrade the “xbox one x“ they copied the design from the ps4 that the air ventilation is on the side panels..
Michael Creech - Yanıt Paylaş
My xbox one s stopped working after a power surge from a string of storms. It wont respond, make any noise at all. I figured i would replace the power supply and see if that’s the fix. While i’m waiting for the part to arrive, i’m wondering if there is any other damage that could’ve been done by the surge. Or does the power supply prevent that?
quintalnick - Yanıt Paylaş
did you ever get that storm Xbox to work? I just lost mine to a storm last night :(
Adam Portugali - Yanıt Paylaş
my one s is working fine all apps are good my network connection is goood its cleaned and maintenanced properly all is working well until i try doing the one thing i bought it for playing games doesnt matter if its disc or downloaded soon as it loads and im ready to play the console crashes to no signal and shuts off
spanky8623 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 115
Son 30 gün: 497
Her zaman: 89,143
