Ana içeriğe geç
Xbox One Wireless Controller (1697 Model) D-pad Replacement
Neye ihtiyacın var
  1. Xbox One Wireless Controller (1697 Model) D-pad Replacement, D-pad: adım 1, 3 resimden 1. Xbox One Wireless Controller (1697 Model) D-pad Replacement, D-pad: adım 1, 3 resimden 2. Xbox One Wireless Controller (1697 Model) D-pad Replacement, D-pad: adım 1, 3 resimden 3.
    • Remove the side handles with the iFixit plastic opening tool by wedging it around the seam of the handles.
    • Be careful not to break the clips when removing the handles.
  2. Xbox One Wireless Controller (1697 Model) D-pad Replacement: adım 2, 1 resimden 1.
    • Remove the battery cover and the batteries by sliding the cover up.
  3. Xbox One Wireless Controller (1697 Model) D-pad Replacement: adım 3, 1 resimden 1.
    • Remove the two screws (four total screws) on the top and bottom of each controller handle and one screw underneath the battery pack using the T9 Torx screwdriver.
    • The screw underneath the battery pack is located under the sticker.
  4. Xbox One Wireless Controller (1697 Model) D-pad Replacement: adım 4, 3 resimden 1. Xbox One Wireless Controller (1697 Model) D-pad Replacement: adım 4, 3 resimden 2. Xbox One Wireless Controller (1697 Model) D-pad Replacement: adım 4, 3 resimden 3.
    • Remove the front cover of the controller. using the spudger.
  5. Xbox One Wireless Controller (1697 Model) D-pad Replacement: adım 5, 1 resimden 1.
    • Remove the back cover of the controller using the spudger.
  6. Xbox One Wireless Controller (1697 Model) D-pad Replacement: adım 6, 2 resimden 1. Xbox One Wireless Controller (1697 Model) D-pad Replacement: adım 6, 2 resimden 2.
    • Remove the metal ring surrounding the D-pad.
  7. Xbox One Wireless Controller (1697 Model) D-pad Replacement: adım 7, 1 resimden 1.
    • Remove the D-pad from the device.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Hellow mine has a problem that it doesn't work\turn on with battery or with a cable like its dead
Abdulhamid - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 24
Son 30 gün: 120
Her zaman: 9,685
