Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Bumpers on an Xbox One Wireless Controller 1697 may become less responsive over time due to extended wear and tear. If the bumpers on your controller become loose over time or break, use this guide to replace the bumpers on the controller.
Neye ihtiyacın var
Remove the battery pack cover.
Remove the two AA batteries.
Carefully remove the sticker or puncture to reveal the screw.
The bumpers are connected by a middle plastic cover that is around the Xbox home button. Remove this plastic piece by lifting the plastic cover over the two pins, pressing the home button in, and pushing the cover towards the top of the controller.
Be aware of the sync button loosely placed under the plastic covering. Ensure it is put back before putting back the bumper/plastic cover assembly.
Remove the current bumper assembly by pulling them off the plastic cover.
Your device is now ready to be used.
60 farklı kişi bu kılavuzu tamamladı.
12 Yorum
You should add a security hex screwdriver to your tools list, along with the gauge that is required.
There is a fifth screw in the battery compartment that holds the faceplate on. Take an exacto knife and cut out sticker where the hole is.
Could you elaborate on the “remove the bumpers” part (last step) please, thank you.
Great guide. Helped me easily fix a sticky bumper and save 60$
