Ana içeriğe geç
Xbox One Wireless Controller 1697 Thumbstick Replacement
Neye ihtiyacın var
  1. Xbox One Wireless Controller 1697 Thumbstick  Replacement, Thumbstick: adım 1, 1 resimden 1.
    • Slide the battery pack cover toward the top of the controller to remove it.
    • Remove batteries.
  2. Xbox One Wireless Controller 1697 Thumbstick  Replacement: adım 2, 2 resimden 1. Xbox One Wireless Controller 1697 Thumbstick  Replacement: adım 2, 2 resimden 2.
    • We recommend using a plastic spudger to prevent damage to your controller. However, using a metal spudger, as shown in the picture, makes the work easier.
    • Hold firmly the controller, place the spudger into the top seam of the controller and carefully work all the way to the bottom.
    • Pry the side of handle away from the controller by moving the spudger back and forth around the side handle's seam.
    • Repeat this process for both side handles.
  3. Xbox One Wireless Controller 1697 Thumbstick  Replacement: adım 3, 2 resimden 1. Xbox One Wireless Controller 1697 Thumbstick  Replacement: adım 3, 2 resimden 2.
    • Using the T8 Security Torxs screwdriver, remove the five 10mm screws from the back of the controller.
    • One of the screws is hidden behind the label.
    • You can punch a hole using a screwdriver or peel off the label.
  4. Xbox One Wireless Controller 1697 Thumbstick  Replacement: adım 4, 3 resimden 1. Xbox One Wireless Controller 1697 Thumbstick  Replacement: adım 4, 3 resimden 2. Xbox One Wireless Controller 1697 Thumbstick  Replacement: adım 4, 3 resimden 3.
    • Remove the back plate.
  5. Xbox One Wireless Controller 1697 Thumbstick  Replacement: adım 5, 1 resimden 1.
    • Remove the faceplate
  6. Xbox One Wireless Controller 1697 Thumbstick  Replacement: adım 6, 3 resimden 1. Xbox One Wireless Controller 1697 Thumbstick  Replacement: adım 6, 3 resimden 2. Xbox One Wireless Controller 1697 Thumbstick  Replacement: adım 6, 3 resimden 3.
    • Select the thumbstick that you want to replace and pull it off its pole.
Sonuç
28 farklı kişi bu kılavuzu tamamladı.
Emely
866 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S9-G1, Remmell Fall 2017 USF Tampa, Team S9-G1, Remmell Fall 2017 üyesi
USFT-REMMELL-F17S9G1
4 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
Hello. I have an controller but it isn't working right. The right stick wont register when i push it down. I spilled cola on it. Any tips?
Isak - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 36
Son 30 gün: 234
Her zaman: 22,859
