Giriş
This guide will teach you how to replace the D-pad.
Neye ihtiyacın var
Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
Use a screwdriver and punch a hole directly in the center of the label.
Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
44 farklı kişi bu kılavuzu tamamladı.
7 Yorum
Can you show me how to replace xbox one controller 3.5mm stereo jack dpad
This model of the xbox one controller does not feature a 3.5mm headphone jack. Please look at the guides for later models of the xbox one controller.
Brandon -
it's exactly the same like shown above :)
