Ana içeriğe geç
Xbox One Wireless Controller Model 1708 Cover Plate Replacement
Neye ihtiyacın var
    1. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Cover Plate: adım 1, 2 resimden 1. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Cover Plate: adım 1, 2 resimden 2.
      • Slide the battery cover toward the top of the controller to remove it.
      • Lift up the batteries or the battery pack from the battery compartment.
      FixBot'a Sor
      Yorum Ekle
    2. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: adım 2, 2 resimden 1. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: adım 2, 2 resimden 2.
      • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
      • Continue using the opening tool to gently pry the side plate off of the controller.
      • Repeat this process for the second side plate.
      FixBot'a Sor
      Yorum Ekle
    3. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: adım 3, 1 resimden 1.
      • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
      • Remove the five 9mm torx-9 security screws from the back of the controller.
      FixBot'a Sor
      Yorum Ekle
    4. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: adım 4, 2 resimden 1. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: adım 4, 2 resimden 2.
      • Orient the controller so the front plate is facing up.
      • Lift the front cover off of the controller.
      FixBot'a Sor
      Yorum Ekle
    5. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: adım 5, 1 resimden 1.
      • Turn the controller face down and gently lift the rear plate.
      • Be careful with the rumble motors, as they tend to fall out, risking damage to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    6. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: adım 6, 3 resimden 1. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: adım 6, 3 resimden 2. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: adım 6, 3 resimden 3.
      • Tape the Rumbler/shock motors in place.
      • This will prevent the motors from falling out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
62 farklı kişi bu kılavuzu tamamladı.
Weston Gilmore
2.158 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G3, Forte Fall 2017 Cal Poly, Team S18-G3, Forte Fall 2017 üyesi
CPSU-FORTE-F17S18G3
4 Üyeler
49 adet Kılavuz yazıldı
5Kılavuz Yorumları
i used a t8 and it worked
Rudy Bp - Yanıt Paylaş
T9 is VERY snug. T8 would probably be better but I don’t have one to try.
Craig Ferguson - Yanıt Paylaş
T9 barely fits, I couldn’t even get 2 of the screws to turn. I think T8 works better
Baron Kube - Yanıt Paylaş
One frustrating thing. All the guides I find on iFixit never give tips on reassembly. I'm having a difficult time getting the back plate back on. No help here, unfortunately.
Jim Pennington - Yanıt Paylaş
how to remove from ass
Mr Rump - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 100
Son 30 gün: 494
Her zaman: 37,735
