Ana içeriğe geç
Xbox One Wireless Controller Model 1708 Trigger Caps Replacement
Neye ihtiyacın var
  1. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement, Trigger Caps: adım 1, 2 resimden 1. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement, Trigger Caps: adım 1, 2 resimden 2.
    • Slide the battery cover out and remove it.
    • Remove the battery pack.
  2. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: adım 2, 3 resimden 1. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: adım 2, 3 resimden 2. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: adım 2, 3 resimden 3.
    • Insert a plastic opening tool between the handle and the plate.
    • Gently slide the opening tool from the top end to the bottom end of the seam to remove the plate from the handle.
    • Repeat the process with the other side plate.
    • The plate is tightly sealed on the handle, so it may be difficult to remove.
  3. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: adım 3, 2 resimden 1. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: adım 3, 2 resimden 2.
    • Remove the five 2.3mm screws on the bottom plate with a T8 Torx security Screwdriver.
    • If there is a sticker on the back, poke a hole with the screwdriver to get to the fifth screw.
  4. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: adım 4, 2 resimden 1. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: adım 4, 2 resimden 2.
    • Remove the bottom plate.
  5. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: adım 5, 3 resimden 1. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: adım 5, 3 resimden 2. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: adım 5, 3 resimden 3.
    • Carefully turn over the controller with the front plate facing you.
    • Remove the front plate.
  6. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: adım 6, 3 resimden 1. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: adım 6, 3 resimden 2. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: adım 6, 3 resimden 3.
    • Remove the two 1.7mm screws from each of the triggers with a T6 Torx screwdriver.
    • It is best to do one trigger cap replacement at a time.
  7. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: adım 7, 3 resimden 1. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: adım 7, 3 resimden 2. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: adım 7, 3 resimden 3.
    • Be careful not to let the trigger motor inside come out.
    • Lift the trigger cap off the trigger motor.
  8. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: adım 8, 3 resimden 1. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: adım 8, 3 resimden 2. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: adım 8, 3 resimden 3.
    • Place the new trigger cap on the trigger motor.
    • Push down the inside of the trigger cap until you hear a click.
    • Repeat step six to eight for the other trigger cap.
Sonuç
To reassemble your device, follow steps 1-5 in reverse order.
19 farklı kişi bu kılavuzu tamamladı.
Ekip
UC Davis, Team S1-G6, Andersen Winter 2020 UC Davis, Team S1-G6, Andersen Winter 2020 üyesi
UCD-ANDERSEN-W20S1G6
3 Üyeler
4 adet Kılavuz yazıldı
1Rehber Yorum
Et le reboitage stp non parce que je pense que ses le plus compliqué.
Yoann.cadenat - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 87
Son 30 gün: 384
Her zaman: 24,341
