Ana içeriğe geç
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. Xbox Controller cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Xbox One Wireless Controller Teardown, Xbox One Wireless Controller Teardown: adım 1, 1 resimden 1.
    • First take off the back two pieces, you might need something to stick in in order to pop them out
  2. Xbox One Wireless Controller Teardown: adım 2, 1 resimden 1.
    • Screw off all the screws, 1 screw is in the middle, and the 4 other screws are in each corner
  3. Xbox One Wireless Controller Teardown: adım 3, 2 resimden 1. Xbox One Wireless Controller Teardown: adım 3, 2 resimden 2.
    • After all the screws are off, now you can pop off the front plastic plate
  4. Xbox One Wireless Controller Teardown: adım 4, 2 resimden 1. Xbox One Wireless Controller Teardown: adım 4, 2 resimden 2.
    • Not you can pop off the back plate
  5. Xbox One Wireless Controller Teardown: adım 5, 1 resimden 1.
    • So how does the electricity works;It uses electricity from the batteries. Also how it works; when you press a button it will stop the electricity and transmit inputs into the game
  6. Xbox One Wireless Controller Teardown: adım 6, 1 resimden 1.
    • STICKS - The Sticks are the same 10k POT style as previous controllers, but are new and smaller than the 360 versions. They have a 1.8v AN+ that comes from a Regulator (U8) and it's also the vRef for U1 on the MCU board.
  7. Xbox One Wireless Controller Teardown: adım 7, 1 resimden 1.
    • The Triggers use Linear Hall Sensors now, U10 (RT) and U11 (LT). They have 3 pins, 1 - VDD (power), 2 - Output, 3 - VSS (ground). The VDD for them comes from U9, which is turned on/off by U1 at 125Hz, 8ms period, On ~1.4ms, Off ~6.6ms (~18% Duty Cycle). This is done mainly to save power.
  8. Xbox One Wireless Controller Teardown: adım 8, 1 resimden 1.
    • The Power board has 3 parts U1 is for when the USB cable is attached, it takes the 5v and knocks it down to ~3v for the other two circuits. U2 is for a 3.5v source that powers the LED, IR LEDs and the Rumble motors. It's TP7 on the MCU board. U3 is for the 3.3v source that powers pretty much everything on the MCU board. It's TP9 on the MCU board.
Rodulfo Macaalay
167 İtibar
1 Kılavuz yazıldı
2Kılavuz Yorumları
A lot of help, thanks. I got an elite 2 so figured if see whats inside my stock boy
Nicholas Pratt III - Yanıt Paylaş
Well, I was looking for an actual teardown, but it just stops after taking the outer shell off and just talks about some of the internals. Needed the instructions for a full teardown to fix face buttons.
Marques Jones - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 27
Son 30 gün: 105
Her zaman: 4,176
