Ana içeriğe geç
Xbox One Wireless Controller Thumbstick Replacement
Neye ihtiyacın var
    1. Xbox One Wireless Controller Thumbstick Replacement, Battery Pack: adım 1, 1 resimden 1.
      • Remove the battery pack cover.
      • Remove batteries.
      FixBot'a Sor
      Yorum Ekle
    2. Xbox One Wireless Controller Thumbstick Replacement, Side Handles: adım 2, 2 resimden 1. Xbox One Wireless Controller Thumbstick Replacement, Side Handles: adım 2, 2 resimden 2.
      • We recommend using a nylon spudger for this step. A metal spudger is shown.
      • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
      • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
      FixBot'a Sor
      Yorum Ekle
    3. Xbox One Wireless Controller Thumbstick Replacement, Screws: adım 3, 2 resimden 1. Xbox One Wireless Controller Thumbstick Replacement, Screws: adım 3, 2 resimden 2.
      • There is a hidden screw located in the middle of the controller behind the label.
      • Use a screwdriver and punch a hole directly in the center of the label.
      • You may also lift the label if you do not want to puncture it.
      • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Xbox One Wireless Controller Thumbstick Replacement, Backplate: adım 4, 1 resimden 1.
      • Remove the backplate.
      FixBot'a Sor
      Yorum Ekle
    5. Xbox One Wireless Controller Thumbstick Replacement, Faceplate: adım 5, 1 resimden 1.
      • Remove the faceplate.
      FixBot'a Sor
      Yorum Ekle
    1. Xbox One Wireless Controller Thumbstick Replacement, Thumbstick: adım 6, 2 resimden 1. Xbox One Wireless Controller Thumbstick Replacement, Thumbstick: adım 6, 2 resimden 2.
      • Remove thumbsticks by pulling them up off their poles.
      FixBot'a Sor
      Yorum Ekle
Sonuç
205 farklı kişi bu kılavuzu tamamladı.
Garrett George
6.482 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-15, Maness Winter 2015 Cal Poly, Team 20-15, Maness Winter 2015 üyesi
CPSU-MANESS-W15S20G15
5 Üyeler
62 adet Kılavuz yazıldı
32Kılavuz Yorumları
Is there any advice for a controller that has had this repair, but continues to drift? I have done this repair successfully many times, and now i have a controller that (with 2 different replacement parts) continues to drift.
Is there a reset or config I can do?
Jim - Yanıt Paylaş
Drift issues are a different problem you would need to solder a new joystick box to fix that this is for loose or damaged thumb sticks
myhero667 - Yanıt Paylaş
I used a cotton ball on my Xbox one Elite to fix drifting issues.
ajcroyle - Yanıt Paylaş
Does anyone know the correct SKU for the joystick box for the Model 1537 in particular? And any link to purchase it. Thanks
ZuYao - Yanıt Paylaş
Can i apply 2 thumbsticks off the xbox 360 controller when i removed them?
Merlijn Fransen - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 23
Son 7 gün: 197
Son 30 gün: 811
Her zaman: 404,285
