Ana içeriğe geç
Xbox One X Lower Metal Case Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Xbox One X Lower Metal Case Replacement, Remove the sticker: adım 1, 2 resimden 1. Xbox One X Lower Metal Case Replacement, Remove the sticker: adım 1, 2 resimden 2.
    • Use blunt tweezers to peel off the sticker covering the right-side screw on the back of the console.
    • Before starting this guide: Turn off the device. Then, unplug any cables from the console.
  2. Xbox One X Lower Metal Case Replacement, Remove the external screws: adım 2, 1 resimden 1.
    • Use a T10 Torx screwdriver to remove the two 12.6 mm–long screws located on the back of the console.
  3. Xbox One X Lower Metal Case Replacement, Slide the upper case horizontally: adım 3, 2 resimden 1. Xbox One X Lower Metal Case Replacement, Slide the upper case horizontally: adım 3, 2 resimden 2.
    • Rotate the console 90 degrees.
    • Pull the front of the upper plastic case horizontally toward the front of the console until it comes to a stop. This slides the clips out of the slots on the upper plastic case.
  4. Xbox One X Lower Metal Case Replacement, Lift the upper case off the lower case: adım 4, 2 resimden 1. Xbox One X Lower Metal Case Replacement, Lift the upper case off the lower case: adım 4, 2 resimden 2.
    • Rotate the console 90 degrees so that the back is facing you.
    • Lift up the left side of the upper plastic case (as viewed from the back of the console), stopping when it won’t lift any further.
  5. Xbox One X Lower Metal Case Replacement: adım 5, 3 resimden 1. Xbox One X Lower Metal Case Replacement: adım 5, 3 resimden 2. Xbox One X Lower Metal Case Replacement: adım 5, 3 resimden 3.
    • While continuing to hold the left side of the upper plastic case, push up on the right side to move the right-side screw boss out of the way.
    • If pushing up on the case doesn't work, try moving it in different directions until it can swing open.
    • Swing the upper plastic case open to 75 degrees.
  6. Xbox One X Lower Metal Case Replacement: adım 6, 2 resimden 1. Xbox One X Lower Metal Case Replacement: adım 6, 2 resimden 2.
    • Push the upper plastic case down and away from the console to remove it completely.
  7. Xbox One X Lower Metal Case Replacement, Disconnect the ribbon cable: adım 7, 3 resimden 1. Xbox One X Lower Metal Case Replacement, Disconnect the ribbon cable: adım 7, 3 resimden 2. Xbox One X Lower Metal Case Replacement, Disconnect the ribbon cable: adım 7, 3 resimden 3.
    • Use the pointed end of a spudger, an opening tool, or your fingernail to flip down the small, hinged locking flap on the ribbon cable ZIF connector on the front circuit board.
  8. Xbox One X Lower Metal Case Replacement, Disconnect the ribbon cable: adım 8, 1 resimden 1.
    • Use blunt tweezers to pull the ribbon cable down out of the connector.
  9. Xbox One X Lower Metal Case Replacement, Remove the front circuit board screws: adım 9, 1 resimden 1.
    • Use a T8 Torx screwdriver to remove the three 13.3 mm screws securing the front circuit board to the upper metal case.
  10. Xbox One X Lower Metal Case Replacement, Remove the front circuit board: adım 10, 2 resimden 1. Xbox One X Lower Metal Case Replacement, Remove the front circuit board: adım 10, 2 resimden 2.
    • Pull the front circuit board straight out away from the upper metal case and set it aside.
    • Grip the board on either side of where it is plugged in to avoid bending and damaging it.
  11. Xbox One X Lower Metal Case Replacement, Remove the upper metal case screws: adım 11, 1 resimden 1.
    • Use a T10 Torx screwdriver to remove the six 47.7 mm screws securing the upper metal case to the lower plastic case.
    • Use a T8 Torx screwdriver to remove the two 7.5 mm screws securing the press connector to the upper metal case.
  12. Xbox One X Lower Metal Case Replacement, Detach the press connector: adım 12, 2 resimden 1. Xbox One X Lower Metal Case Replacement, Detach the press connector: adım 12, 2 resimden 2.
    • Insert the flat end of a spudger underneath the press connector on the side opposite of the ribbon cable.
    • Use the spudger to lift the press connector up and away from the upper metal case.
    • Don't push the spudger all the way to the socket. Prying up the socket may damage it.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  13. Xbox One X Lower Metal Case Replacement, Remove the lower plastic case: adım 13, 3 resimden 1. Xbox One X Lower Metal Case Replacement, Remove the lower plastic case: adım 13, 3 resimden 2. Xbox One X Lower Metal Case Replacement, Remove the lower plastic case: adım 13, 3 resimden 3.
    • Flip the console over.
    • Hold on to the lower plastic case because it is no longer attached to the metal case.
    • Lift the lower plastic case up from the metal case and set it aside.
  14. Xbox One X Lower Metal Case Replacement, Remove the lower metal case screws: adım 14, 1 resimden 1.
    • Remove the two T10 Torx screws securing the lower metal case:
    • One 7.7 mm screw
    • One 11.4 mm screw
  15. Xbox One X Lower Metal Case Replacement, Remove the lower metal case: adım 15, 1 resimden 1.
    • Lift the lower metal case up off the upper metal case and internal components.
    • The disc drive may lift up with the lower metal case. Hold it down during this step.
    • Set the lower metal case aside.
Sonuç
Kyle Smith
40.872 İtibar
123 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 134
