Ana içeriğe geç
Xbox Philips DVD Drive Disassembly
Neye ihtiyacın var
  1. Xbox Philips DVD Drive Disassembly, Hard Drive: adım 1, 1 resimden 1.
    • Make sure your Xbox is safely unplugged and is laying on a flat, stable surface.
  2. Xbox Philips DVD Drive Disassembly: adım 2, 1 resimden 1.
    • Turn the Xbox over to reveal the four rubber feet.
    • Use a metal spudger to pry off the four rubber feet.
  3. Xbox Philips DVD Drive Disassembly: adım 3, 2 resimden 1. Xbox Philips DVD Drive Disassembly: adım 3, 2 resimden 2.
    • There are 2 more screws hidden under the two labels on the bottom of the case.
    • You can either remove the labels or simply feel for the screw holes through the labels and then cut or punch a hole through them.
  4. Xbox Philips DVD Drive Disassembly: adım 4, 1 resimden 1.
    • Remove the six T20 Torx screws securing the top cover to the bottom cover.
  5. Xbox Philips DVD Drive Disassembly: adım 5, 2 resimden 1. Xbox Philips DVD Drive Disassembly: adım 5, 2 resimden 2.
    • Once the bottom and top shells are no longer attached, carefully turn the Xbox right-side-up, lift and remove the top cover.
  6. Xbox Philips DVD Drive Disassembly: adım 6, 2 resimden 1. Xbox Philips DVD Drive Disassembly: adım 6, 2 resimden 2.
    • Remove the three 3 mm T10 screws securing the hard drive to the Xbox.
    • There is one screw on the rear left side of the hard drive that is only visible when the IDE ribbon cable is lifted up. The other two are at the front right and left sides of the hard drive.
    • The screw on the lower left corner of the disk drive is not in the hole that it appears to be in, but rather just closer to the corner.
  7. Xbox Philips DVD Drive Disassembly: adım 7, 2 resimden 1. Xbox Philips DVD Drive Disassembly: adım 7, 2 resimden 2.
    • Free the hard drive power cable from the carrier for sufficient slack to lift the hard drive out.
    • Lift the plastic hard drive carrier out of the Xbox case.
  8. Xbox Philips DVD Drive Disassembly: adım 8, 3 resimden 1. Xbox Philips DVD Drive Disassembly: adım 8, 3 resimden 2. Xbox Philips DVD Drive Disassembly: adım 8, 3 resimden 3.
    • Remove the four 3.4 mm T15 Torx screws from the plastic hard drive carrier (two screws per side).
    • Carefully remove the hard drive from the plastic carrier. Gentle rocking will see the hard drive come out quite easily.
  9. Xbox Philips DVD Drive Disassembly: adım 9, 2 resimden 1. Xbox Philips DVD Drive Disassembly: adım 9, 2 resimden 2.
    • Pull both the hard drive data ribbon cable and the power cable straight up from the hard drive.
    • They may be firmly seated, so be careful trying to remove them. DO NOT pull the wires as you may damage the cable assembly.
  10. Xbox Philips DVD Drive Disassembly, Disc Drive: adım 10, 3 resimden 1. Xbox Philips DVD Drive Disassembly, Disc Drive: adım 10, 3 resimden 2. Xbox Philips DVD Drive Disassembly, Disc Drive: adım 10, 3 resimden 3.
    • Remove the disk drive. It should come right out.
    • Unplug the ribbon cable and yellow cables from back of disk drive.
  11. Xbox Philips DVD Drive Disassembly: adım 11, 1 resimden 1.
    • Pry back the black plastic tabs around the disk drive in order to remove it from its housing. Once removed, set the drive aside.
    • If you are removing the disk drive in order to gain access to the motherboard underneath, you do not need to remove the plastic housing.
  12. Xbox Philips DVD Drive Disassembly, Remove Top Shell: adım 12, 2 resimden 1. Xbox Philips DVD Drive Disassembly, Remove Top Shell: adım 12, 2 resimden 2.
    • Remove 4 PH2 screws
    • Remove top cover
  13. Xbox Philips DVD Drive Disassembly, Manually Eject Drive: adım 13, 3 resimden 1. Xbox Philips DVD Drive Disassembly, Manually Eject Drive: adım 13, 3 resimden 2. Xbox Philips DVD Drive Disassembly, Manually Eject Drive: adım 13, 3 resimden 3.
    • With the pointed end of a spudger slide this piece to the right
    • Laser assembly will drop about a quarter inch
    • Drive door will open about a quarter inch and can now be manually opened
  14. Xbox Philips DVD Drive Disassembly, Manually Close Drive: adım 14, 3 resimden 1. Xbox Philips DVD Drive Disassembly, Manually Close Drive: adım 14, 3 resimden 2. Xbox Philips DVD Drive Disassembly, Manually Close Drive: adım 14, 3 resimden 3.
    • Gently slide drive door closed.
    • Slide this piece to the left.
    • Laser assembly will raise about a quarter inch.
    • Drive door is now secured.
  15. Xbox Philips DVD Drive Disassembly, Remove Lower Shell: adım 15, 1 resimden 1.
    • After removing the lower shell DO NOT place the drive down as you typically would. You may damage the lower ribbon cable rendering the drive useless
  16. Xbox Philips DVD Drive Disassembly, Pull Cables From Brackets: adım 16, 2 resimden 1. Xbox Philips DVD Drive Disassembly, Pull Cables From Brackets: adım 16, 2 resimden 2.
    • Loop the wires out from their retaining brackets.
  17. Xbox Philips DVD Drive Disassembly, Separate PCB: adım 17, 3 resimden 1. Xbox Philips DVD Drive Disassembly, Separate PCB: adım 17, 3 resimden 2. Xbox Philips DVD Drive Disassembly, Separate PCB: adım 17, 3 resimden 3.
    • With the drive upside down, gently pull back on the ribbon cable retaining tabs and pull out the ribbon cable.
    • There are 2 plastic tabs and 1 post holding the board in place. Lift up on the post, slide PCB to the left and then forward.
    • Reverse process to reattach PCB
    • Rotate PCB right and place to the side
    • There's just enough length in the cable to place the board in a PCB holder to replace capacitors.
Sonuç
Navy Vet 2015
7.460 İtibar
15 adet Kılavuz yazıldı
Bir Yorum
This is for the VAD6035/21
Jason - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 26
Son 30 gün: 97
Her zaman: 6,329
