Ana içeriğe geç
Xelio P1001A-BK Back Cover Replacement
Neye ihtiyacın var
  1. Xelio P1001A-BK Back Cover Replacement, Back Cover: adım 1, 2 resimden 1. Xelio P1001A-BK Back Cover Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the two 3 mm retaining screws from the side of the tablet with a Phillips #0 screwdriver.
  2. Xelio P1001A-BK Back Cover Replacement: adım 2, 2 resimden 1. Xelio P1001A-BK Back Cover Replacement: adım 2, 2 resimden 2.
    • Insert the plastic opening tool in between the shelf halves and lift the top shelf half to detach the securing tabs.
    • There are four securing tabs located on each long side.
    • Before fully separating the shell halves, observe if the speakers are separated from the shell half. If they are still in their sockets, gently pry them loose with the plastic opening tool.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Josh Saenz
316 İtibar
3 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 4-2, Panko Spring 2015 Colorado Springs, Team 4-2, Panko Spring 2015 üyesi
UCCS-PANKO-S15S4G2
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 15
Her zaman: 257
