Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the two 3 mm retaining screws from the side of the tablet with a Phillips #0 screwdriver.
Insert the plastic opening tool in between the shelf halves and lift the top shelf half to detach the securing tabs.
Remove the micro-SD card from the card slot if a card is in the slot
Remove the motherboard to screen ribbon cable
Pry the ribbon cable retaining tab loose with plastic opening tool.
Slide the ribbon cable out from the connector.
Remove the camera from its socket. Do not remove the camera ribbon cable.
Remove the two motherboard retaining clip screws with a No. 0 Philips head screwdriver
Remove the retaining clip from the board.
With the No. 0 Phillips head screwdriver, remove the two screw that hold the function and volume control switch assembly to the tablet.
Remove the two screws that secure the micro-SD card reader to the tablet frame
Remove the three screws that secure the motherboard to the tablet frame
Gently lift the motherboard free from the tablet frame and turn it over to expose the opposite side. This will expose the power socket solder pins.
Be cautious when turning the board over as another ribbon cable, the speaker wires, battery wires, and Wi-Fi antenna wire as still connected to the motherboard.
Place the new part on the board
Solder the new part into place
Place the motherboard back into its proper position but do not reinstall the securing screws yet.
Plug the tablet power supply into the power socket
Using a volt-ohm meter, touch the meter probes to the battery wire points on the motherboard to ensure voltage is getting to the battery.
