Ana içeriğe geç
Xelio P1001A-BK Speakers Replacement
Neye ihtiyacın var
  1. Xelio P1001A-BK Speakers Replacement, Back Cover: adım 1, 2 resimden 1. Xelio P1001A-BK Speakers Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the two 3 mm retaining screws from the side of the tablet with a Phillips #0 screwdriver.
  2. Xelio P1001A-BK Speakers Replacement: adım 2, 2 resimden 1. Xelio P1001A-BK Speakers Replacement: adım 2, 2 resimden 2.
    • Insert the plastic opening tool in between the shelf halves and lift the top shelf half to detach the securing tabs.
    • There are four securing tabs located on each long side.
    • Before fully separating the shell halves, observe if the speakers are separated from the shell half. If they are still in their sockets, gently pry them loose with the plastic opening tool.
  3. Xelio P1001A-BK Speakers Replacement, Speakers: adım 3, 2 resimden 1. Xelio P1001A-BK Speakers Replacement, Speakers: adım 3, 2 resimden 2.
    • Desolder the two speaker wires with the soldering iron by melting the solder so the wires can be removed.
    • Remove the wires from the soldering points once they have loosened.
    • Use a soldering vacuum to remove the excess solder from the board.
  4. Xelio P1001A-BK Speakers Replacement: adım 4, 1 resimden 1.
    • Inspect your wires. You should see 2 mm of exposed wire before you move to the next step.
    • If necessary, use your wire-stripping tool to strip 2 mm of insulation from each wire.
  5. Xelio P1001A-BK Speakers Replacement: adım 5, 1 resimden 1.
    • Place the exposed wire in the soldering point.
    • Apply the soldering iron to the point just until the wire is secured.
    • Repeat these two steps for the second wire.
Sonuç
Josh Saenz
316 İtibar
3 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 4-2, Panko Spring 2015 Colorado Springs, Team 4-2, Panko Spring 2015 üyesi
UCCS-PANKO-S15S4G2
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 156
