Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the two 3 mm retaining screws from the side of the tablet with a Phillips #0 screwdriver.
Insert the plastic opening tool in between the shelf halves and lift the top shelf half to detach the securing tabs.
Desolder the connection on the motherboard.
Use a soldering vacuum to remove any excess solder.
Use wire strippers to strip off at least 2 mm of wire insulation from each wire.
Solder the outer wire braid shield to the ground point.
